Old 05-16-2005   #6
Re: boost or timing for hp
Boost makes crap loads more power than timing. DSMs aren't the most timing sensitive cars either. They don't have big power gains when you add 2 degrees like some cars. Shoot for something like 15-16 degrees and as much boost as it will take on pump gas. 2Gs don't need as much timing as 1Gs, due to the higher compression. You could run more timing, but I would just go for higher boost.
