Old 06-15-2005   #1
TurboDomestics
TurboDomestics's Avatar
pass window has trouble going down, and wont go up
whenever I push the botton for the pass window to go down, it goes drop 2-3 inches, and then it tries to go down more but has a lot of trouble doing so, and after it goes down those 2-3 inches it cant go up at all without some one pulling it up with their hand. And it sometimes gets off track, when i move it up. When I took the door panel off to see if there was any obvious problem, i noticed two cables holding on the track, but the one on the bottom was very loose, I didnt check the motor, because i couldnt find my multimeter, but i think its fine. Do you think this cable could cause it to jump off the track making it real hard for the motor to pull the window down? can this cable be tightened or do I need to replace it?
anything else you guys think could be wrong with it?
thanks
-Charlie
4G63 0, Charlie 3
