Old 06-20-2005   #18
howslowcanyougo
Older than Dirt...
howslowcanyougo's Avatar
Drives: IX EVO MR/SE
Re: Bastard 20G?
Just saw this post up at "tooners".....
Looping the waterlines is a super easy job. A 12" piece of hose and loop from one to the other, no big deal.
Oil cooled turbos are designed to be only oil cooled and will last just as long as an oil/water cooled turbo. Generally most guys racing run the bearing out of the turbo from high speed and high load long before heat will ever kill it. You must still cool an oil cooled turbo the same as a oil/water cooled turbo, the procedure is no different. Most turbo manufacturers (Turbonetics / Precision / Garrett) recommend only 30 seconds of cool time after a hard drive. I personally have put over 75,000km (50,000 miles) on my last oil only turbo (on a Turbo VW) and it was no different in shape then my T25 that came off my current car with 50,000 miles on it.
http://www.dsmtuners.com/forums/show...ock+waterlines
So can you really just loop the turbo waterlines together for a V Trim install or?
TIA...
Let the madness begin...
