Old 06-28-2005   #7
Re: basic idle issue
Your fast idle air valve could also be bad. If the ISC is bad then it should do funky idle stuff all the time (up and down repetitions).
Your reverse gear does not have synchros and if the edges of it are worn out then you have to be at a complete stop and the lower the engine speed is better at lining up the gearing. You probably just have a worn out reverse gear.
