Old 07-26-2005   #1
howslowcanyougo
Older than Dirt...
howslowcanyougo's Avatar
Drives: IX EVO MR/SE
Wierd Boost leak test results?
I have a 98 Tsi, AWD. I just installed a new Bastard 20G turbo from Slowboy and a FMIC from Extreme. Now it runs pretty laggey, but still needs to be tuned. It does have the supporting fuel, exhaust and engine management mods installed and setup. Even though it holds 20 LBS to Redline, it still feels weak for what it should be pulling? Also has a Greddy Type S that I can't yet stop from fluttering?
One of the first things I tried to do was tested for boost leaks using a boost leak tester, but when I put in only <5lbs of pressure to the turbo intake, I heard this weird gurgling/Bubbling noise from the motor instead of finding a hissey leak?
I can't even finish the boost test the way the Vfaq shows how to because it won't hold any pressure at the intake inlet, as the pressure just bubbles/gurgles away?
And Wow it really seems like there alot of misinformation out there on the subject?
Please help me clear this up gurrgling once and for all!
I've been around to a several DSM boards and they all say this bubbling/gurgling sound is one or more of the following:
A. Normal, when not running and oil pressurized the air will slide past the turbos oil seals, blasting air through the turbo down through the dump tube into you oil pan.
B. Not normal you have bad oil seal in your turbo, and you need it fixed.
C. The Air is blowing buy your rings, valve seals, or egr into the crankcase?
D. You have a cracked Head or bad head gasket.
E.You need to turn the motor over to TDC before running a boost leak test?
F. You are hosed, and have Demon's or UFO's, sell your DSM?
Seems like a bunch of people have this same issue, yet there is no CLEAR cut answer out there to if it this gurgling sound is really is normal or not?
I did call Curt at Slowboy Racing, and he said if it didn't smoke it was ok, but he hadn't ever heard of the problem, so this made me nervous, as none of my other turbos gurgled when they were boost leak tested.
Like I told Curt at slowboy, if there's a issue on this brand new turbo with the seal, I'd rather know NOW, stop and ship it back for repair, than to run it and blow the turbo out completely.
This brand new turbo cost me $1100.00 and theres no way I'm going be the one getting the shaft on it if somethings wrong with it!
Is my Brand NEW turbo already shot or is this gurgling normal or is there another real answer?
Now this morning, I go out and try another leak test, no gurgles this time, just starts to build a tiny bit of pressure and I now hear it air rushing straight out though the oil filler hole, and still not holding any pressure?
Like what ever oil that was gurgling last night when I did the same test, had drained down and now I'm just hearing the raw "leak"?
How can this happen?
Do I really need the motor at TDC to run this Boost leak test or is this deal really just a red herring or what?
Let the madness begin...
