Old 07-26-2005   #7
91nbtsi
Send a message via AIM to 91nbtsi Send a message via MSN to 91nbtsi
Re: Ways to safe fuel.
Originally Posted by Goat Blower
If your injectors shut off completely, your engine would stall. And letting off the gas using the engine for braking is the same as using your brakes since your taking your foot off the gas and applying it to the brake. Except for those two-footed drivers out there.
Um, they shut off completely. As Shane said, they come back on at whatever rpm your decel fuel is set to shutoff, be it in your stock ecu or whatever you use.
Just because you let off the gas doesn't mean you have to step on the brakes, does it? haha. If you let the engine do more of the braking, before you hit the brakes, it will save a small amount of fuel each time..not saying you are even going to notice, but it will.
10.806@133.15--1991 Talon
91nbtsi is offline   Reply With Quote
