Old 11-19-2006   #21
Thor06
11 Seconds to Freedom
Thor06's Avatar
Re: How much power with 750cc's and e85?
Yeah, thats why my buddies professors said too. I wouldnt worry about it at all. How lean can you go on E85?
Old 11-19-2006   #22
Yea, eff that coating business. If some X number of years down the road your shit looks questionable, just get a new fuel rail!
Old 11-19-2006   #23
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
The best part of running e85 is having the freedom to run high boost at all times. Who really can afford to run race gas daily?
Old 11-19-2006   #24
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
This is sounding tempting...for the colt. 60/40 eh?
Old 11-19-2006   #25
I'm looking to do this for next season. I'm looking at the FIC 1150 injectors, keeping the stock fuel lines, and the 255hp pump on my 50 trim setup. If the 255 get's maxed out, I'll probably be going with that Bosch 044 pump.
I remember this being discussed a long time ago, but does anyone ground their fuel pump or anything when running e85 since it apparently is a conductor of electricity?
Old 11-19-2006   #26
Gasoline conducts electricity. Should we ground the pump now? Gasoline burns easier than e85, so I would guess that you are safer with e85 uner most conditions.
So, as long as I don't store the car for a logn period with e85 in the tank or fuel lines, it should be fine? And convert to non-rubber soft fuel line.
Old 11-19-2006   #27
K smartass, thanks for that.
They install some sort of flame suppressors in the FFV vehicles, and it has something to do with how e85 conducts electricity from what I gathered. And I know a long time ago Eric had mentioned grounding our fuel pumps because we don't have that supressor. Is anyone grounding any additional components, or just running the cars as they are?
Old 11-19-2006   #28
Wow, that is interesting because this is a quote straight off the US DOT website "Ethanol and Ethanol blends conduct electricity. Gasoline, by contrast, is an electrical insulator."
http://www.chemtrec.org/NR/rdonlyres...elMixtures.pdf
Old 11-19-2006   #29
rst95eclipse
I must say that I haven't seen any writeups about E85 convert cars having corrosive problems. I even read about a Mustang that has been running on it for over a year without any sign of wear on the fuel system. The most interesting point he made was the fact that he did not protectively coat anything.
Old 11-20-2006   #30
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
It's a very slow process. Some rubbers and uncoated aluminum can slowly weaken or oxidize. I don't know any concrete numbers, but I expect it's years before any problems make themselves known. For those of us who pull most of those parts off on a semi regular basis it shouldn't be a problem to check and replace/upgrade accordingly.
Old 11-20-2006   #31
Alright, I was wrong, (Sorry brandon) according to them, but thank you for that link, it is quite interesting. Just below that tidbit is another, more interesting fact:
At low temps (32*F) e85 vapor is more flamable than gasoline vapor.
edit: nvm.
Edit: also, I just read that the vapor settles in low spots, so would there need to be mods to the gas tank?
Old 11-20-2006   #32
You guys are overthinking this. Put it in, tune accordingly and have fun. You'll be replacing engines before your aluminum parts disintegrate from an ethanol blend.
Old 08-09-2007   #33
HKSenilyks
Send a message via AIM to HKSenilyks
My fuel system consists of a walb255, FPR, and 720cc injectors. I'm using a 20g turbo, do you think I could tune that with my safcII or do I need better tuning capabilities?
Thaught
HKSenilyks is offline   Reply With Quote
Old 08-09-2007   #34
ExTREME
ExTREME's Avatar
http://forums.evolutionm.net/showthread.php?t=269341
^750's(i think), 20G, Boom.
I was just reading a shit-ton on this stuff.
DSMLINK forums has some more shit, just search e85 in google.
Heres the spoon for your mouth
I plan to run e85 on 850's, E316G, 255 wally, afpr and all on a tune via DSMLINK.
I've been looking to find any current setups running near mine to find out what ratios and volumes to set my 'link to.
only 1800$ and ill be writing up a thing or two on this e85 on a 16G poop. Can't wait to smell like the alley behind a bar!
Old 08-09-2007   #35
HKSenilyks
For some reason the first link wouldn't work. Dsmlink would be nice but I can't afford it right now, what do you think about tuning that much fuel with a safcII?
Thaught
Old 08-09-2007   #36
ExTREME
ExTREME's Avatar
Hmm..Link works for me. Check the google link, that is where I first came across the evomn link.
Old 08-09-2007   #37
You'll be fine. E85 takes roughly 30% more fuel to run stoich, so you only need to subtract about 19% fuel at idle and part throttle to make 720's work. Well within the range of a SAFC2.
Old 08-09-2007   #38
HKS: What MAS are you running?
As far as tuning, 720s+ E85, should work very well with an SAFC on paper, better than trying to tune them on pump gas with all the timing side effects you run into with having to go very negative on the SAFC.
The biggest problem will be the car making too much power and maxing out the 720s early. 720s on E85 are comparing in power handling to 510-550cc injectors on normal gas.
Old 08-10-2007   #39
That answer is good enough for me. Just too bad it took 9 months to get it.
Old 08-10-2007   #40
ExTREME
ExTREME's Avatar
I found some good equations in that evomn site figuring out e85 and what injectors but I'm not a math-magician so I don't really know how far my 850's will get me with an E316G w/2g MAS n' 255 AFPR.
