Old 06-26-2007   #21
driftn1g
Re: removing the awd system from tranny
no its disconnected.. im just confused on where to pry it, and how bad im going to bust my knuckles ha
so my blue mark is where it meets and is correct??
Old 06-26-2007   #22
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Perhaps the 2g install will be easier to understand.http://vfaq.com/mods/clutch-2G.html
I can't tell in your picture. Is there a seperation under your blue line? Honestly it's been a while since I've done this. I'd go out and look at mine but I bet it's still hot out....
If you want to get a good idea of what the mating points between axle and tranny are just pull the drivers side one first. It doesn't need to be pried.
And wear gloves. Knuckle busting is inevitable.
Old 06-26-2007   #23
driftn1g
drivers on is out... didnt need to be pried like u said...
In that pic, the tranny is above and the thing im pulling out is below, but looks like it would be hard to get in there and pry it
Old 06-26-2007   #24
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Give me some money, and I'll do it for you.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 06-26-2007   #25
driftn1g
HJ?
jk ahaha.. ill figure it out
FUCK i need to make it by july 8th!!!!!!!
Old 06-26-2007   #26
Wow.
Transfer case is held on by 5 bolts. That might need some coaxing to get it off the output shaft. Then make sure to support the center driveshaft.
On the front passanger side axle
It would be best to pry alongside the axle/transmission meeting point UNDER the car as there is a bit more room for a pry-bar/even application. A quick "pop" motion should dislodge the axle from the transmission.
Good luck.
Old 06-27-2007   #27
Jeez, newbs helping newbs. No, you don't have to separate the axles from the hubs, just undo the 2 bolts between the strut and the hub. Niterydyr is right for the T-case and you also need to get the DP out of the way, the t-case sits right beside it. There are also 2 bolts holding the intermediate shaft on (drivers side axle) if you haven't found them yet, 14mm.
Old 06-27-2007   #28
LEADING THE
If you are really this new to working on these cars, get a copy of the DSM service manual cds. They are really nice.
You can seperate the strut from the hub assembly as metioned above or the ball joint. The axles will pop out of the FWD portion of the transmission with a pry-bar. Be sure to remove the two bolts holding driver's side axle support bearing. The transfer case is easy to remove once the down pipe is out, as mentioned above. Just remove the bolts and will easily slip off the intermediate shaft.
Old 06-27-2007   #29
xveganxcowboyx
Wanker
Drives: 95 M3
Do you not then have to swing the hub outward and seperate the two?
Old 06-27-2007   #31
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Originally Posted by 2003eclipse View Post
I have a small feeling this car is never going to run again
j/k
Ditto
- Josh L.P.
Old 06-27-2007   #32
driftn1g
LOL.. IVE done everything you guys are ranting about...
Im going out to go work on my car
she will run again
Old 06-27-2007   #33
Yeah I forgot the mention removing the downpipe and unbolting the hubs/seperating the axles on that end, I assumed he would atleast be that far.
Thanks for the back-up posts guys.
Old 06-27-2007   #34
driftn1g
k i got those hubs and cv boots figured out
Old 06-27-2007   #35
Hoffer00
Fight Man Champion! Cantankerous Tank Champion! Go Johnny Go Champion!
Send a message via Yahoo to Hoffer00
You might get it running again. Just remember cars need oil to run. Unless you like buying new engines.
Hoffer00 is offline   Reply With Quote
Old 06-27-2007   #36
driftn1g
not my fault
i had an oil change not even 1500 miles ago
Old 06-27-2007   #37
Hoffer00
That thing must leak like a som beyach
Old 06-28-2007   #38
iceminion
iceminion's Avatar
If you cannot read up on how to remove the transmission/transfer case...
GET SOMEONE TO HELP YOU
This is mostly a local site, and most of us are broke/sober enough to do it for cheap/beer
building a 3000GT AWD Turbo.
Old 06-28-2007   #39
driftn1g
dude its done.. i did it..
this thread is 3 months old now where u been
Old 06-28-2007   #40
Actually, it's just about 1 day old. Don't be a dick when people try to help you with something that appears to be over your head.
