Old 11-11-2008   #21
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
Re: Head Games: pushing coolant and then...
if i didn't just get home I'd come help you
Old 11-11-2008   #22
hmm, I just started cooking my dinner, abd by the time I get done, it'll probably be too late. Working early in the morning sucks ass...
Old 11-12-2008   #23
Thanks for the offers guys! I actually made a lot of progress on my own last night:
-stopped by MAP and picked up my Kelford 272's and GSC springs *TWO* days early!
-removed strut tower bar
-unhooked all catch can/kracka vent plumbing
-unhooked/untangled all wiring
-unbolted fuel rail/injectors
-removed spark plugs
-drained coolant
-set TDC
-valvecover off
-broke cam gear bolts loose
-zip tied tbelt to gears and strung it up to my old hood prop
-unhooked all coolant lines
-unhooked upper IC pipe and got everything else out of the way
So ya, ready to unbolt cams and headstud bolts and get that mutha off of there! I got home late from work (about 7pm, don't say that's not 'that' late cause I worked a 17 hour 'shift' on the day before!) so I did not get it all the way off. Called it quits around 10pm, just too much other stuff going on to keep going.
Also, I'm getting a few points of advice:
-Leave headstuds in, clean with brake cleaner and shop towels till its so clean I can eat off of it.
-Remove headstuds, use fine sand paper to *lightly* clean the surface of the block, then brake cleaner and shop towels till its clean.
Any votes yay/nay the sandpaper? I imagine it's only necessary if there's a lot of gunk on the block, and even then it should be light light lightly used.
Old 11-12-2008   #24
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
I would say use a shop vac before wiping with a towel and brake cleaner to get the majority of the metal dust flakes off. That's the last thing you want in this engine! and good progress. now with having zip tied the timing belt to the cam gears are you hoping to hot have to redo the alignment or whats up with that?
Old 11-12-2008   #25
unbolt cam gears from cams, then pull head and leave all other timing stuff untouched. I just did the timing belt twice, I don't really want to do it a third time.
Old 11-12-2008   #26
If you can get all the old gasket stuff off the block without sandpaper or razor blades or what have you, then do that. You could even maybe use adhesive remover soaked into a rag/towel to loosen up left over gasket stuff, that last part was a guess, I've never done it before, but hey, might work. I have used a razor though, and you just have to be careful.
Old 11-12-2008   #27
It is an iron block, scrape away with a razor blade. Carb cleaner works good for removing copper spray.
Old 11-12-2008   #28
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Is it possible to put a MIVEC head on an Evo8? I know they wouldn't have the wiring or anything, just wondering if the block is the same or if there are any extra oil passages added. Crank pickups the same? Just a thought...
Old 11-12-2008   #29
Good progress Scheides, I should be able to come help tomorrow night if you're gonna be working on it
Old 11-12-2008   #30
mdost03
Sonic Champion!
Drives: VA STI
I would just take the timing belt and gears off, make it a lot easier IMO to get everything put back together and get yourself a little more room to work. You aren't that much away from taking it completely off.
Old 11-12-2008   #31
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
When I did mine I used carb cleaner and scotch brite pads. They worked great.
-1990 Mitsubishi Cyborg 4WD-
Old 11-12-2008   #32
I think its possible, there might be one extra cooling passage that is bigger on the IX block though.
Kewl, come over around 7, we'll be rockin.
Like I said, just got done doing this twice, not pumped about doing it again. If I have to, I will.
Old 11-13-2008   #33
The new goodies! Kelford 272 cams and GSC 5039 Beehive springs
And, here's our problem spot:
Head looks good! Taking it in for a cleaning and checkup anyways
And bottom end looks happy too. I could not have imagined how much cleaning is needed on the top of the block though...gonna take a while
Cyl walls look happy for putting down decent power for 30-40k HARD miles:
Head goes to Gosh tomorrow...
Old 11-14-2008   #34
cleaning the block surface suuuuuuuuuuuuucks
Old 11-14-2008   #35
For sure dude, I had no idea it was gonna be such a biotch
Old 11-14-2008   #36
MustGoFaster
Composite gaskets are easier to clean up after, MLS's are a bitch.
Old 11-14-2008   #37
Yeah, I'd take out the headstuds and the two guides, clean up the surface, then put them back in before dropping the head back on. I can't believe how much the heads are similar to the 1G on the combustion side. I thought they'd be totally different for some reason.
Old 11-14-2008   #38
We did end up taking the headstuds out to make things easier.
Old 11-14-2008   #39
mdost03
Sonic Champion!
Drives: VA STI
I thought it was the other way around? At least in my cases it has been composites are bitches to clean up. My MLS on my talon was a piece of cake to clean.
Was gonna say you probably should to make life easy haha. It's not like it's tough to take them out anyways.
Old 11-14-2008   #40
Just hose it down and throw it back together. haha jk
Good luck on the install dude!
