Old 11-09-2008   #1
Head Games: pushing coolant and then...
So first off I must say that my evo has been the most reliable turbo awd mitsubishi I've ever owned. And the most powerful...not insane power, but 300+whp for daily use is just endless fun.
About 3 weeks ago I pulled into my work parking lot and the temp gauge went way high, almost to gauge max. It quickly went back down, but I could not help but wonder wtf the deal was! I got home and discovered that the coolant was low. The car was just rolling over 60k miles, and I had plans to do the timing belt with the water pump anyways, so I ordered all the parts and decided to get that out of the way before I jumped to too many conclusions. I found a TSB for 05 Evos regarding premature water pump failure, so this just backed up me doing the water pump sooner than later.
After some leaky water pump issues, I got the car running good and not loosing any coolant with gentle driving and light boost. I had turned down the boost, timing, and richened up the tune to keep things gentle on the car. After some WOT testing, I suspected coolant being lost still but thought maybe I had overfilled it, had air bubbles, blah blah blah, I made lots of excuses to tear my mind away from the obvious.
I did a compression test: 182 175 180 175.
I changed the thermostat. I changed the radiator cap. Still, no matter what I've done, if I boost the car, coolant finds its way out of the overflow bottle. The cap even blew off a few times, but it turns out I had accidently folded the rubber seal over a bit on the cap, which I think led to this.
I turned the boost back up. The car rips as normal, full power is about 380whp (dyno dynamics) on my E85 tune and the car drives perfectly. However, when I park the car and let it cool, coolant is low....obviously low. Probably filled it with about a 20 oz bottle several times. So, I turned the boost back down.
I did a leak-down test. Not really looking for results form the gauge, just mostly looking for bubbles or movement in the coolant. I'm guessing the 100psi (gauge max) I put on the cylinder is not enough to simulate cylinder pressure under boost, as I saw nothing.
I talked to shane @ DB through all of this, and he was very helpful in giving me ideas of stuff to try, but in the end he advised that when cars have symptoms like this that are not diagnosable with regular tests, that a headgasket or warped head are to blame.
The car has overheated a few times. At about 25k miles, 2 years ago, I blew out the freeze plug from the water pump, which promptly pumped out all of the coolant. I got the car over to the side of the road fairly quickly, found the freeze plug and tapped it back in, and drove it ever since. I had Shane @ DB install a set of arp head studs 1x1 method when he was putting in my cams.
Also, last winter my crank pulley got ripped off by a chunk of ice on the freeway. I tried to limp the car back to my house, but realized shortly therafter that the acc belt ran the water pump. The car got a little hot then too.
So anyways, just looking for feedback, anyone with any ideas of what I could try before pulling the head off. I have some other plans, but I'll fill you in on those later.
Old 11-09-2008   #2
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: Head Games: pushing coolant and then...
Before you pull the head off, you should pull the valve cover off. Just do it and be done.
Old 11-09-2008   #3
I'm going to guess its the head gasket too
Old 11-09-2008   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Sorry to say but it indeed does sound like a headgasket. I had the same symptoms with my 1g after 1x1 arp install. Didn't really show up til I started tuning more aggressively also. Either way a headgasket isn't all that hard. Just think of it as a time to upgrade!
-1990 Mitsubishi Cyborg 4WD-
Old 11-09-2008   #5
There is a chemical test to check for headgasket leaks. Very accurate and simple, a solution goes into a tube, any gases leaked from the combustion chamber into the coolant react with the solution and cause an obvious color change. You can also sniff for hydrocarbons in the overflow bottle, but you need an exhaust gas analyzer.
Old 11-09-2008   #6
Where can I get one of those coolant test kits?
Old 11-09-2008   #7
I had the exact same thing last fall, no signs of it on a compression test, just low coolant and some white smoke. New gasket fixed it right up.
Old 11-09-2008   #8
Sorry to hear, but everything is pointing to a HG.
Also the car would be reliable if its only a few years old.
Hell my has been reliable for the last few years with a 160k stock bottom end heavily street raced and tracked.
Old 11-09-2008   #9
Ok, thanks for the advice guys. Now onto the yummy details! As a good DSM'er, I can't well pull my car apart and not find a way to put a little more juice in it! I want to be certain the head isn't warped, so I'm sending it to John Gosh to get checked out. I goobered up one of the bolt-holes for the intake manifold when I had it out so that will get heli-coiled. I'm also going to get a new set of valve springs to get installed, and a little hotter set of cams than I have now to up the ante a bit.
I've LOVED my HKS 280's, but after 30k miles with them I'm ready to try something else, so they are officially FOR SALE! $450 obo!
The new springs will be a basic upgrade, no dual spring titanium retainer setup for me. The cams will be streetable and powerful, proven to make power on a stock, unported head.
Old 11-09-2008   #10
Probably Napa or other similar auto store.
Old 11-09-2008   #11
Let me get this straight, my old POS DSM is more reliable than Scheide's EVO? Say it ain't so.
Old 11-09-2008   #12
Steve, I put more miles and WOT pulls on this thing in a month than your 1G sees in a year and you know it!
Q: when I pull the head, should I remove the headstuds or leave them in? Would it be wise to pull them before re-installing?
Old 11-10-2008   #13
taking them out will make dropping the head on easier, I'd think.
And I have to say, if this is your most reliable car, I can't imagine what you'd been driving before (i know, a 2g, but still).
Modded cars have a shorter life span than stock/unmolested ones.
Old 11-10-2008   #14
Shitty. If you need help getting it apart let me know
Old 11-10-2008   #15
Leave the headstuds in, that way the head is lined up perfectly and you'll have less chance of smearing your copper spray around and getting a good seal.
Old 11-10-2008   #16
Thanks for the advice Steve!
Mark, I will have Anna make you dinner if you come help me, that includes free puppy-sitting too! I'm thinking about tearing it apart Thursday after work. Sounds like all of the stuff I've ordered should be in by then.
here's what I got on order:
Kelford 272 cams (I/E)
Duration @0.1mm: 272/272
lift: 11.0mm/11.0mm
duration @1mm:226/226
centerline @ full lift: 107/113
Compared to my 'old' HKS 280's (sniff, love these things!)
HKS 280
Advertised Duration - 280 deg
Effective Duration - 222 deg @ 1mm
Lift - 10.8mm Int / 10.2mm Exh
Lobe Centerlines - 110 deg Int / 110 deg Exh
LSA - 110 deg
Stock valve springs OK
And compared to stock:
Factory EVO
Advertised Duration - 260 deg Int / 256 deg Exh
Effective Duration - ___ deg @ 1mm Int / ___ deg @1mm Exh
Lift - 10.0mm Int / 9.5mm Exh
Lobe Centerlines - 109 deg Int /111 deg Exh
LSA - 110 deg
Also a set of GSC's 5039 springs:
The GSC Beehive spring is a factory replacement and will use your stock OEM retainer and Valve Seat to ensure an easy install.
Spring Pressures :
Seat @ 1.56"=68 lbs / .300"=160lbs / .400"=190lbs / .450"=210lbs / .625"= Coil bind.
*Max lift on stock Retainer is 11.4mm at the valve or .259" cam lobe lift.*
So ya, that and an oem headgasket from Brookdale and we're in business! I have some small side projects in mind, but nothing major. I'll take pics as things progress. Wish me luck!
Old 11-10-2008   #17
311evo
311evo's Avatar
good choice on cams
hopefully the HG should seal everything up for ya!
Old 11-10-2008   #18
Dang dsms... Modded cars I tell ya.. Hope the headgasket fixes it up!
Old 11-10-2008   #19
I may be able to come over thursday or friday after I get off work and lend a hand if you need.
Old 11-11-2008   #20
Holy shit, just got word from MAP that my springs are in already, I JUST ordered them YESTERDAY. Mad props to MAP!
Looks like I'll start pulling stuff apart tonight...anyone wanna help?
