Old 05-10-2010   #21
Re: Spark Plug Gap?
My Buschur COP uses the 300 coils and they work. Why the hate?
Old 05-10-2010   #22
Cammaxon
Brian Spilner called...
Cammaxon's Avatar
Drives: RR EVO Viii 493AWHP Spilner Mobile(sold)
Re: Spark Plug Gap?
The bad thing about getting new wires is that i relocated the coil pack when i put my JMF SMIM and ONE wire is too short so i had to call mangacore and order just one of the longest wires. If i bought a set id have to do something stupid like that again or buy TWO sets and that would BLOW
I Like Cheese
Cammaxon is offline   Reply With Quote
Old 05-10-2010   #23
twack
It was a auto get over it
twack's Avatar
Re: Spark Plug Gap?
you could get a set with custom sizes, or you could just order from a different car that has the sizes you like.
but i think your overthinkning this issue. check your coil pack for arcing and multimeter it, then check your wires, and see if they are arcing on the spark plug cover where you drilled through it, they may be rubbing. You arnt still using those iridiums that you had at my house are you? and for good times sake, do a boost leak test!
Old 05-10-2010   #24
Cammaxon
Cammaxon's Avatar
Re: Spark Plug Gap?
NONO i got new plugs at DBs the day of my tune. I'm gonna throughly investigate tonight. Call me Maxon PI! Boost leak test is in the works for tom if things don't pan out tonight. Eagle Talon Guy has a tester so hopefully i can take him away from his NEON for long enough to do it.
I Like Cheese
Old 05-11-2010   #25
Cammaxon
Cammaxon's Avatar
Re: Spark Plug Gap?
Replaced a few things i had been meaning to get at tonight. Throughly inspected plugs, gapped them to 23/24, and wires. Coil pack turned out Good to go. Replaced a fuel line that was in need of some attention. Replaced an UICP coupler and a Tbolt clamp and i replaced the hose from my BOV into my intake.
Solid, strong pulls with no misfires
Thanks for the advice! See you all saturday! Don't let Spilner put down bigger numbers than you!
I Like Cheese
Old 05-11-2010   #26
Re: Spark Plug Gap?
Change your spark plugs every other oil change ($7 is worth it). That was my policy, and it worked wonders. 0.22 ftw, never misfired on e85 and high boost.
