Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Closed Thread
Old 03-08-2007   #421
Re: Finally getting stuff done on our cars
Then I will look at a 44 or 46 Tial or similar.
Pushit2.0 is offline
Old 03-08-2007   #422
PSI2HI
Your just gonna have to trial and error w/ boost control and monitoring back pressure ratio's. Problem is if you set it up for single gate your kinda stuck w/ a single gate unless you kind find some way of cutting the wastegate runners off and salvaging the collector. Baller up and get a TIAL 60mm :-p
PSI2HI is offline
Old 03-08-2007   #423
"Boost control" is a realative term on this car.
Just want to keep it under 40psi.
Running twin gates or single?
Not to bad, pluggin away waiting for winter to be done.
Yeah same here. Go away snow!
niterydr is offline
Old 03-08-2007   #424
It should be easy to add another Tial off the #2/3 collector. It would just be re coating the manifold.
Old 03-08-2007   #425
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
Looks nice John hope to see that White Nissan running again.
Josh LaCroix
92EvilTalon is offline
Old 03-08-2007   #426
PSI2HI
Whatever happened to your talon?
PSI2HI is offline
Old 03-08-2007   #427
Sitting in the garage, it was good practice but I do not know if the car will be put together at anypoint. It seems that the full tube chassis with a fiberglass body is the way to go now days.
Old 03-08-2007   #428
Depends if you are trying to actually run in a class though, or just run a fast time or run fast and still street drive it.
Shane@DBPerformance is offline
Old 03-09-2007   #430
Originally Posted by rst95eclipse View Post
Why is Swanny in the closet? Swanny come out of the closet.
What in the hell are you talking about?
niterydr is offline
Old 03-09-2007   #431
niterydr is offline
Old 03-09-2007   #432
Sweet guys! But how are you going to fit the 1g MAS in there?
Halon is offline
Old 03-09-2007   #433
We have a shrink ray, patent pending.
niterydr is offline
Old 03-10-2007   #434
Looks badass. Is there a reason for not aiming the turbo outlet right at the intercooler to give it a shorter route?
Matt D. is offline
Old 03-10-2007   #435
I thought about doing that but I would have to make both endtanks custom. Then I do know know where I would put the BOV, it is a Greddy Type R so its not a small bov, Also it is a tight fit as it is with the big water to air over the tranny.
Old 03-10-2007   #437
I may be missing something here but isn't running a single wastegate defeating the purpose of running a divided turbine housing and manifold?
Jakey is offline
Old 03-10-2007   #438
http://www.lseperformance.com/galler...g2_itemId=3324
The waste gate will only be on the #2/3 collector, so the manifold will stay divided, if it runs less then 30psi I will be happy, race gas and track times are all I care about right now. If the boost goes low enough it will get a full pump gas tune, if not I will add another waste gate off the #1/4 collector.
Old 03-10-2007   #439
I thought about that too since the IC piping ends up being rather long. It would be a biscuit to make the custom end tanks, but if you clocked the compressor cover to point up, make the IC inlet face down to join up with just a coupler, then integrate a BOV into the IC outlet endtank, you'd have it. Mucho fabrication though. Might be a good project for myself when I get GT42 upgradeitus in the next year or so.
Looks good, should be a monster when it's done.
Goat Blower is offline
Old 03-10-2007   #440
Why does it matter once the turbo is spooled?
Matt D. is offline
Closed Thread
