Old 07-27-2010   #1
Re: Evo X upgrades
Is there any way you could mount the camera in-car next time? That would be pretty sweet.
Old 07-28-2010   #2
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I have one of those GoPro HD cameras but I haven't tried it out yet (some people say that the video sucks). I've always had an instructor with me so far (why not, paying for it) and I didn't need the additional distraction. Maybe next month.
Old 07-28-2010   #3
Re: Evo X upgrades
Worry more about your driving than the logging, sounds like the car is running pretty damn good Sucks your PLX gauges are giving you a hassle though. Do you plan to keep them or go another route?
You can get new hardware for your exhaust from any hardware store; ACE sells automotive grade bolts/nuts.
Old 07-28-2010   #4
Re: Evo X upgrades
QFT. All the damn gadgets in the world won't make you a better driver. After all, that is why you built the car, right? To drive?
Old 07-28-2010   #5
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
One day at BIR per month and the rest of the month to fiddle with stuff. I'll let my 'pit crew' (brother & his wife) play with the cameras.
I was concerned about checking the AFR a few times just because the setup hasn't been beat on like that before. It held up quite well. The car is incredibly smooth out there. I just need practice with choosing the best gear and some auto-x/car control courses to get a feel for where the limits are.
Old 07-28-2010   #6
Re: Evo X upgrades
Autocross is awesome for finding the limit of a car, then bushing beyond it. I spun my IX a few times just finding the edge and pushing past it to see how the car reacted. Well, that and running too much rear tire pressure
Old 07-28-2010   #7
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I have a big investment so I'd certainly like to see them work. The question is if that's possible. They are one of those companies that doesn't have a tech support phone number...you email and they don't reply. If I don't get an RMA for the OBD gauge then that one will probably just remain dark. I have AFR & Boost on the other gauge and those are the important ones, anyway.
I picked some up at O'Reillys yesterday but got M8 and I need M10 by the looks of it. I'm going to swing by scheides tonight in case I have to cut the existing bolt off (no power in the ramp at home).
Old 07-28-2010   #8
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Perrin shipped a new fmic. I found out that both of their fmic offerings for the X are powder coated, so I went with Silver this time. It should be less noticeable if it peels.
I picked up some larger exhaust bolts and an angle grinder. Super-sized Dremel ftw.
Old 07-29-2010   #9
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Got the exhaust leak fixed last night. Drove the Evo to work to wash it over lunch and I have no boost. I'll be poking around to figure that out today.
Old 07-29-2010   #10
Re: Evo X upgrades
Old 07-29-2010   #11
Re: Evo X upgrades
I think I told you about the friend of mine with the audi last night? WGA arm fell off his turbine/wastegate flapper. Something to check.
Old 07-29-2010   #12
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
scheides is a fucking genius.
/case closed
Old 07-29-2010   #13
Re: Evo X upgrades
/case closed
LMFAO! How the hell is that possible! It happened on the SAME DAY! Unreal. Slap that thign back on and boost boost boost!
Old 07-29-2010   #14
bananas
bananas's Avatar
Drives: A4
Re: Evo X upgrades
/case closed
Crazy!
http://www.youtube.com/watch?v=6dmraBaOmtU
My fix:
bananas is offline   Reply With Quote
Old 07-29-2010   #15
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Originally Posted by bananas View Post
Crazy!
I picked up a clip with a lock as well. It's a little longer than I'd like but I hope it works. I'm going to run to scheides' tonight since getting the arm back in place with compressed air would be a lot easier than strongarming it.
Old 07-29-2010   #16
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
First time i did the WGA tightening i used my hands, it was real hard, and actually i had to back it off one turn because i just couldn't get it...second time was at noob mod day at Scheides...WAY EASIER! Good choice.
Old 07-29-2010   #17
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Man, no boost now /pray something easy.
Old 07-29-2010   #18
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I'm not going to panic until I check all the little lines (like the one to my boost gauge).
The silicone coupler that comes off the bottom of the fmic and to the lower IC pipe rubs against the bracket that was for the stock lower IC pipe. UR's lower pipe didn't allow enough clearance and I didn't have anything to cut it off with last Sept when I installed that stuff.
Perrin has already shipped my new FMIC so I was planning to put my new angle grinder to good use. It may have beat me to the punch, though.
Old 07-29-2010   #19
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
I know that is where my coupler popped off more than once...
I would just try and check it sooner rather than later with the BBX failures that have gone on. Maybe pull the intake and check the wheels if you can. You don't want to end up like rogue with a toast motor
Old 07-29-2010   #20
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
What happened to the motor? I know that the turbo failed.
I was definitely planning to pull the intake tonight and give the wheels a wiggle.
