Old 08-30-2010   #1361
Re: Evo X upgrades
Let's see, maf is 36% bigger so drop maf scaling by about that much, injectors are double, so 2x scaling + the new injector latency fix and use the supplied (?) latencies, then put in psi-boost hack w/ zero CF, fire up the car, cross fingers and go baby go!
Just kidding, it's a little more involved than that. I will be very interested to see how the psi-based boost control works out for ya on the street!
Old 08-30-2010   #1362
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
That's so damn easy, why bother with Shane?
Old 08-30-2010   #1363
Re: Evo X upgrades
Blasphemy! The man is filled with bad, bad ideas to make every car faster/better
Old 08-31-2010   #1364
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
30-32...sigh...lomker you wuss.
Have I taught you nothing..you need at least 34 psi to make the torque of a 4g63, you don't want to look stupid do you
Ps. I am excited to see what this setup has in it finally...
After months of waiting we will know if the BBX has motor breaking potential in it
Old 08-31-2010   #1365
Re: Evo X upgrades
What do you mean by PSI based boost control? That doesn't make sense to me as PSI = boost. Do you mean RPM boost control? Sorry I'm a newb I guess.
Old 08-31-2010   #1366
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I'm not an ECU geek, that's just what Tephra calls it. By default the X uses load targets and you can't actually tell it to hit a particular psi target. Every dyno you run the car on will hit a different peak boost because it loads the car differently.
The best analogy I've heard is that it will behave like an ECU-adjusted MBC afterward.
http://www.evoxforums.com/forums/sho...893#post522893
Old 08-31-2010   #1367
Re: Evo X upgrades
^Once properly setup that's the idea! Load-based systems work, but they are error prone and thus inconsistent. The biggest saving grace on the X is that it has a low gear range and high gear range have separate base wasgtegate duty cycle (WGDC) tables, which in helps a LOT in the real world.
Old 08-31-2010   #1368
Re: Evo X upgrades
Gotcha, now it makes more sense.
Old 08-31-2010   #1369
Re: Evo X upgrades
English major? I don't know where you got 36% from.
1000cc * 2 != 2200cc. And nothing works right with the huge injectors as far as just doing simple scaling for the size.
Done. PSI base still isn't perfect since it's based on absolute pressure instead of gauge pressure, which most people talk about and absolute will change from day to day based on the barometric pressure, but that's fairly minor.
Well, back to work. The intake scaled fairly decent. Now on to switching the injectors and trying to get the 2200s to behave.
Old 08-31-2010   #1370
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Sweet, now you will have some MAF scalings for my car
Let us know how the injectors work out
Old 08-31-2010   #1371
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Dave's DW1300's are 1400 and my ID2000's are 2240. The injector companies take a horseshoe approach...
Old 08-31-2010   #1372
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Updates?? Are you at work still Lomker or at DB for the tune...if I get no answer I assume you are at DB
Old 08-31-2010   #1373
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
My Dad helped me drop it off last night. I want to save my vacation days for car events.
Old 08-31-2010   #1374
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Fair enough, you picking it up later then I assume?
Old 08-31-2010   #1375
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
If it is done today then I'll get it over lunch tomorrow. I want to install the APR splitter next weekend, otherwise I don't care much.
Old 08-31-2010   #1376
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
My fueling problems continue. 20psi drop in pressure at 7k rpms. Shane is going to check the voltage to the Bosch and I suppose the inline fuel filter should be checked.
The Mitsu gods don't love me.
Old 08-31-2010   #1377
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Geez...why do they hate you so???? Did you anger them? Are you sure you aren't running out of pump, no idea how much that one is supposed to flow.
Old 08-31-2010   #1378
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: Evo X upgrades
If he is running out of pump with 3 fuel pumps total, then i would just say fuck it and reutrn to stock
341hp/344tq E-85 FTW
Shane Tune@ DB
Old 08-31-2010   #1379
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
If I wasn't so deep into this car it'd be getting parted out next week. I'll wait to hear from Shane about what voltages the pump was getting since that'll dictate where to go from here.
I may just have to live with this power level until next year. I could save over the Winter for a fuel cell and just take another step toward hard core.
Old 08-31-2010   #1380
Re: Evo X upgrades
DO it.
