Old 09-08-2010   #1
Re: Evo X upgrades
Originally Posted by mlomker View Post
My understanding is that if you disable it and don't physically remove it then it'll get damaged (we didn't remove it). The X will also continue to throw codes unless you wire in a wideband like scheides has done.
Mine is disabled and removed from the car completely w/o a wideband and I get no codes.
Old 09-08-2010   #2
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
SSDD. Another unique issue for me.
Soak the tips in 1/2" gasoline in a little cup and the gas will turn black absorbing it all in a couple minutes.
I'll do that the next time they are out.
Old 09-08-2010   #3
Re: Evo X upgrades
Alcohol can't dissolve that gooey junk like gasoline does. Soak the tips in 1/2" gasoline in a little cup and the gas will turn black absorbing it all in a couple minutes. There was a big study on this on link awhile back, I can't remember if they determined the source of the black goo that the alcohol can't absorb or not.
Old 09-08-2010   #4
Re: Evo X upgrades
2010 vs 2008. Turning off rear O2 stuff is not as easy with the 2008s.
Old 09-08-2010   #5
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Shane theorized that my oil burning was fouling out the front o2 and causing my problem at cruise. He created a ROM for me that runs in open loop as a test. I went for a short drive and the car ran absolutely awesome. I'll see how it does on tomorrow's commute.
Old 09-08-2010   #6
mdost03
Sonic Champion!
Drives: VA STI
Re: Evo X upgrades
Awesome, glad you are getting somewhere finally.
I think 311evo's car had some o2 sensor problems as well and Shane made a tune similar to your's that only ran it in Open Loop and it ran perfectly afterwards and even got better mileage than he was getting when he used the o2 sensors.
Old 09-08-2010   #7
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I didn't know that! Thanks for the info.
The important thing to me is that I've eliminated the custom Primo intake as being a problem. It's a huge plus when you can isolate something.
Old 09-10-2010   #8
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I've done a number of pulls in the last day to baseline the AFRs before isntalling the afpr and trying the BAP again over the weekened.
I must say, driving that car is like a drug. The only time the cams really lope is right after a hard run...for a few seconds it sounds like Matt D's car. God, I LOVE THAT.
Hope the car is running well for BIR on the 20th.
Old 09-15-2010   #9
Re: Evo X upgrades
Nice on the magnus CMC! Nice work on the on-the-shelf approach, hopefully you never need it!
I can see the smile on your face from here Glad you're really starting to get some time to enjoy this thing!
Old 09-15-2010   #10
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
That way you can call me if you need one? Yeah, having one around for the local X guys was a part of my reasoning.
Old 09-17-2010   #11
Re: Evo X upgrades
Not gonna lie, it makes me feel slightly better knowing that there's one locally but extra good knowing that someone will be putting this through the paces. IDK though, I have nearly 3k on my act 6-puck now, no issues yet (knock knock).
Old 09-17-2010   #12
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I'm nearing 5k. murlo picked it up last night so that part is out of stock at the Lomker warehouse. lol.
Old 09-17-2010   #13
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
I regret replacing my MC ever...so far it has been a money pit.
Old 09-10-2010   #14
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I received the Prosport fuel pressure gauge, DW1300 injectors, and Magnus master cylinder today. My goals for this weekend are to plumb in the afpr and wire in the gauge. The Magnus will permanently go on the shelf "just in case" and the injectors may be returned or resold pending my next visit to DB.
Old 09-11-2010   #15
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Apparently I FAIL at putting connectors on -6an fuel line. It leaked and the line was too short by the time I found a technique to do it correctly. I ordered some more line so I'll give it another try on Monday night.
I got lucky and picked a setting that made my cruise AFRs perfect. If it weren't for the leak then I'd be thrilled. The setup was looking very nice other than that.
Old 09-11-2010   #16
Rmondoh
Minority of MitsuStyle
Rmondoh's Avatar
Drives: '08 OBP Evo X GSR SSS (Deadmau5X)
Send a message via AIM to Rmondoh Send a message via MSN to Rmondoh Send a message via Yahoo to Rmondoh
Re: Evo X upgrades
Glad to see that things are progressing nicely.
08 Evo X GSR - Octane Blue Pearl
Cobb Stg1 AMS 93 OTS: 305hp 291tq 20.6psi
Cobb Stg1 93 Pro: 317hp 322tq 24.5psi
Cobb Stg2 AMS 93 OTS: 315hp 323tq 23psi (LWG map)
Cobb Stg2 93 Pro: 343hp 358tq 26psi
Cobb Stg2 93 Pro: 355hp 361tq 26.4psi (ported stuff)
Rmondoh is offline   Reply With Quote
Old 09-12-2010   #17
Re: Evo X upgrades
That Magnus clutch master cylinder is the best one on the market IMO. The SSP sounds like a total pile of junk...plus it's more expensive.
Old 09-15-2010   #18
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Finally finished the fuel pressure gauge install since my first attempt at the wiring (using a multi-conductor, solid-core wire) didn't pan out. The fuel line went fine last night and doesn't leak. It ended up a little tighter than I'd like but the afpr bracket flexes a little so hopefully it will survive...if not then I have a spare hose on-hand.
Looks like Friday morning's trip to factory MOD with the 3/S group is on. I'll take a lot of pics and shoot some video for you guys.
Old 09-16-2010   #19
Re: Evo X upgrades
Have fun! You guys should all caravan down for the Dallas MOD next year (we're thinking April/May since people complained July was too hot this year).
Old 09-16-2010   #20
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Is it hard to drive an Evo in cowboy boots? I have a pair I haven't worn for years...
Did a couple pulls this morning and AFRs are 11.7 ... works for me.
