Old 04-28-2010   #141
Re: 1992 Eagle Talon TSI Project
Buy a new headgasket, don't pull a Swifail.
nope. no more delays. my car will be running tomorrow for sure. unless i work all night and get my car done and running tonight. lol.
Old 04-29-2010   #142
LingLing
AznKraut
LingLing's Avatar
My only question is, does it run 10's yet?
Old 04-30-2010   #143
ok. so last night we got everything together to verify the engine starts but ran into a minor issue. It wouldnt start.
Checked spark and its getting it. so the ignition system is working.
Checked timing and that is still dead on.
Compression was a bit low (90) but this was likely due to a low battery as it was winding down when i did the test. At least there was some compression.
No fuel. Made sure there was gas in the car by adding some i had in a gas can. Fuel pump is not turning on. I put 12v to the check wire on the fuel pump and the pump turned on. After 3 i will be getting a MPI relay from Mark to see if that is the issue. In the meantime, its time to fill up the tranny and transfer case and start bleeding the clutch and brakes and get some other minor stuff done. then once she is able to be started hopefully i can take her for a spin.
Tom
Old 04-30-2010   #144
LingLing
AznKraut
LingLing's Avatar
Good shit dude! She's come a long way.
Old 04-30-2010   #145
So, why would you fill up the tranny and xfercase *after* trying to start it? Lubrication. Do it dude!
Fingers x'd for MPI relay making this thing finally come to life!
Old 04-30-2010   #146
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
^ doesn't need fluid in the tranny to run. He said START, not RUNNING/DRIVING.
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 04-30-2010   #147
Easiest way to check fuel pump: pull off fuel feed line from rail and see if gas comes out when you turn the key to on.
Hope that MPI relay fixes your issue.
Old 04-30-2010   #148
Transmission components are still moving even if the car isn't.
Old 04-30-2010   #149
Ugh I just cant believe some of the stuff im seeing on style this week. lol And out of OG's.
Old 04-30-2010   #150
We need a list of the OG's here on style. lol
Old 04-30-2010   #151
Just follow the fail trail.
Old 04-30-2010   #152
Check for user id < 500. That should give you a pretty good idea.
Old 04-30-2010   #153
yea it was just to start it, and it didnt. but anyways, transmission and xfer case are filled.
I attached a switch to the pump so that it would come on and i would know its coming on and could feel the fluid going through the lines. But still no gas getting to the pistons.
Is there a fuse for the injectors? or should i be looking at the CAS? I have a spare that i can swap in thankfully.
Old 04-30-2010   #154
You just couldn't wait.
Old 05-02-2010   #155
Swifty1638
Swifty1638's Avatar
http://www.youtube.com/watch?v=0UzsURBwlnk
Tom asked that I post this for him..his car is not firing. Sounds like it's got promise, but no fire, no start. Someone help this fucker get his shit running again.
Black 1GB Mafia #1
I wanna go fast.
Old 05-02-2010   #156
Not on a 1G.
So what all has been verified? Do we know that there is spark, compression, and fuel?
Old 05-02-2010   #157
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Originally Posted by tpunx99GSX
"Compression is good, Plugs are wet when taken out, Timing is dead on. Battery is charged and swapped out a known good, verified CAS is correct, Checked fuses, checked wiring to CAS and Coils, Tried with the aftermarket ignition system and also with the stock ignition system."
http://www.youtube.com/watch?v=tLu4fQB6ql4&hd=1
Posting for tom from the sb
Old 05-02-2010   #158
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
are the wires going to the right plugs? Sounds like they got mixed up.. happend to me and sounded the exact same.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 05-03-2010   #159
tehehodi
Braaaaaaaap!
tehehodi's Avatar
For tom:
Originally Posted by tpunx99gsx
Old 05-03-2010   #160
So what was it?
