View Poll Results: How much WHP will I make on Cobb's AWD Mustang dyno?
<450 2 11.11%
450-475 3 16.67%
475-500 6 33.33%
500-525 3 16.67%
525-550 3 16.67%
>550 1 5.56%
Voters: 18. You may not vote on this poll
Old 08-20-2011   #161
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: SE take two!
Originally Posted by PlanoEvo View Post
Is that a strawberry poptart Gay kitty spouting the gay rainbow spaz?
Meow.
Originally Posted by Trogdor
Old 08-21-2011   #162
Re: SE take two!
You rip! Awesome! I heard this was on a dyno last weekend too? Post up both plots if you can! How's the tuning going?
Old 08-21-2011   #163
Re: SE take two!
It was on a different dyno last weekend but the operator didn't have a clue how to use the dyno and was using weight-based torque...with not even close to accurate weights. He put down 450 WHP last weekend though which seemed about accurate for a Mustang.
Old 08-21-2011   #164
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
yeah the graph from last week is all jagged not pretty and smooth. But went from 449hp last week to 478hp I bumped my timing up 3 degrees and made some slight afr changes mainly in the midrange. Boost remained unchanged from the previous week 28psi at peak torque and 23 at peak hp.Measured Intake air temps were 115+ as air in the dyno room was close to 100F.
Actually, i lied, hang around the drinking league if you want to party hard.
PlanoEvo is offline   Reply With Quote
Old 08-21-2011   #165
Re: SE take two!
I thought you were running 30 psi peak last weekend?
Old 08-21-2011   #166
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Oh yeah thanks I forgot that I turned the mbc back out a little. So actually running about 2psi less at peak trq and 1psi at peak hp compared to last weekend.
Old 08-23-2011   #167
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Results! Be kind self tune Click image for larger version
Boost was tapering bad 23psi at peak hp
Old 08-23-2011   #168
Re: SE take two!
25psi before 3500rpm woot! Goddamn you must just be in heaven, this is a fukin rip of a setup!
Old 08-23-2011   #169
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Hell yeah!!! I just tightened the wga tonight so hopefully it will hold more up top. Then I'm gonna need more fuel and hopefully I can get it somewhere like 32psi tapering to 28-30 that should easily make over 500whp and probably close to 500wtq!!!!!!
Old 08-23-2011   #170
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Actually 26psi at 3500rpm you can go th cobb online and look at the dyno database and look under Evo IX and Andrew Kereluk and see all the details.It builds boost so fucking fast sometimes I wonder what it would be like with the EF4
Old 08-24-2011   #171
Re: SE take two!
Old 08-24-2011   #172
Re: SE take two!
Great results so far Andrew, the progress you made in a week was awesome! This turbo definitely had 500+ in it, and I'm sure you'll be there come the NTEC fall dyno day.
Old 08-24-2011   #173
Re: SE take two!
Damn... That thing has to hit like a freight train at spool-up.
Old 08-24-2011   #174
Re: SE take two!
That friggen boost line just goes straight up!! Awesome setup you got yourself there man. Enjoy it!
Old 08-25-2011   #175
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Yeah before I do a pull it damn near has to be wide open because it reals shit in so fast.On the ntec cruise several people in front of me started a pull on a long straight and I was holding back because I knew and my wife turned and said "come on gas it their getting away" and I said hold on let them get a little farther and I gunned it and came up on them so fast it freaked her out!
Old 09-03-2011   #176
Re: SE take two!
So...I hear you ran 35 psig today
Old 09-04-2011   #177
Re: SE take two!
Like a boss son. Numbers? How does this hog hold boost?
Old 03-10-2012   #178
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Got new shortblock in from Map same as last time except lower CR 9:1 as I am no longer fucking with corn and will run pump. Also upgrading from EF3 to EF4. We got 1 month to get it all back together and drive up for the spring cruise wish us luck!
Old 03-10-2012   #179
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: SE take two!
good luck man
2006 WW IX RS 396/404 - SOLD
Old 03-10-2012   #180
Re: SE take two!
y no corn????
Tags
post liked by shane
