Old 06-28-2008   #1
Dizmm
Dizmm's Avatar
Drives: on ICE
FS: Feeler, 97 Talon TSi AWD Road Race Ready!!!
Well, sorta just testing waters here. If I don’t get near this asking price, I will keep the car for a bit and part it out at another time. If I do sell this car i would really love to see this car go to someone in the road-racing scene as I have spent LOTS of money and LOTS and LOTS of time building this car for road-race use.
To start with, this car performs VERY well and nothing has been hacked, every mod and repair has been done with reliability in mind. There is nothing worse than breaking down at the track.
The motor is a fresh 6 bolt motor with not even 1000k miles on it. Compression is PERFECT! This motor has not seen a big track day yet. get it while she's fresh!!
MODS:
Engine:
6 bot 4g63 2.0L Motor
1g rods w/2g pistons (OEM Mitsu Rings)
ACL Main and Rod Bearings
ARP Main and Head Studs
Forced Performance BIG T28 Turbo
Forced Performance Tubular-Cast Race Manifold
Ported 2g O2 Housing
2.5inch Downpipe
3inch Cat-Back Exhaust
1g Throttle Body
2.5inch I/C Pipes (ASM)
1g Crushed BOV
FMIC (20x10x2.5)
MSD DIS-2 Ignition
DSM-Link V2
3-Bar GM Sensor
FIC 550cc Injectors
Walbro 190LPH Fuel Pump
Water/Alky/meth Injection Kit (Currently running 100% meth)
Dual M7 Nozzles mounted on TB Elbow.
Drivetrain:
Stock Transmission (Shifts like butter!!!)
RRE Light Flywheel
ACT 2600 Clutch (street Disc)
Under-Hood Shift Kit (skateboard bearings)
Suspension & Brakes:
Koni Sport Shocks
GC sleeves, perches, & coaxial hats
RRE pillowballs
HyperCoil Springs (650lb Front / 425lb Rear)
RM-DSM Front and Rear Sway Bars
Redrilled front upper A-arms (2.5 degrees camber)
ES lower front bushings
Flipped driver's compression arm (4.5 degrees caster)
Rear Camber Kit (Shims)
TCE Wilwood Brake Kit (front):
-13in X 1.25in Rotor, Aluminum Hats
-Wilwood FSL 4-plot Calipers
-SS Brake Lines
-PolyMatrix B pads for track, "D" pads for street
ATE Super Blue DOT4 Brake Fluid
17x8 +40mm ASA IS6s with 245/40/17 Kumho SPTs
Interior/Gauges:
Harness Bar
Corbeau Forza Seats
Momo Race Steering Wheel
Sparco 5-point Harness
Boost and EGT Gauges on A-Piller
Weight Reduction:
Full A/C removal
Battery Relocation to Rear
Full Radio and Speakers all Removed
Rear Seats deleted
Bumper Supports
Total Car Weight without Driver = 2900lbs
Car is an estimated 300whp (Dyno'd at 265whp prior to the Meth Injection and at 17psi) Car is currently tuned at 19psi with the meth injection.
My Price is $10,000. If you may be interested in the car but don’t want to spend that much, I do have some of the stock parts such as the brakes setup that I would be willing to work with you, however, the this car is setup perfect just the way it sits, I encourage anyone to come take a ride, you'll love how this thing handles, brakes and accelerates!!!
Any Questions, please email me at andy@northsidecomputers.net
the 2g rod compared to the 1g rod:
Andy Smedegard
Dizmm is offline   Reply With Quote
