Old 01-17-2006   #1
1slowcolt
4g63t in an AWD wagon ??
hey guys im in need of a little help ive read and researched for several weeks now and have not found info on it... i was wondering if its possible to swap the 4g63t motor tranny and transfer case into my 1989 colt DL AWD 5spd wagon like i said ive researched it but only could find info on the hatchback ( prolly cause of the stupidity of swapping that motor into a wagon but i want the ULtimate in Sleeper SUPRISE !!! a worked over 4g63t powered AWD wagon im sure id have to change the motor mounts i know the wirign harness and that stuff needs changed im just lookin to see if i can bol tthe motor in inplace of my 1.8 (4g37)
1slowcolt is offline   Reply With Quote
Old 01-17-2006   #2
x-pride
x-pride's Avatar
Re: 4g63t in an AWD wagon ??
There is only two guys on here that owns a colt GT and only one has the 4g63t swap. You might not get much help here. Best bet is to talk to the guys on www.4g61t.com. I know that people have swap in 4g63t into 89 DL but not AWD. You should just pick up a 89 GT and do the swap that way. It is going to cost you some money to do it the other way around. Here is something that is going to help you decide. To do a swap in a 89GT is going to cost you around 2-3k not including the car. Any how if you want a sleeper the 89GT is the a perfect one. If you can find a turbo scoupe that is a sleeper also. Most people have no idea what a 89GT CSM is. Trust me on this. They think it a honda until its to late. Can you tell I love Tegs. Good luck on your search.
Old 01-17-2006   #3
1slowcolt
thank you for your help !! any more info ppl ?
Old 01-17-2006   #4
I still have one of those AWD's rotting away on a farm. I also had the same idea as you. The engine should swap in pretty easily, but I think you are going to have to use the stock drivetrain. I have no idea how much power that could take. I would definately gut it to keep the weight at a minimum. I doubt it will take much more than 300hp though.
Old 01-17-2006   #5
I haven't seen one to compare, but with most car companies, the 4dr sedans and wagons are basically the say layout mechanically. Just the roof line and rear gate are changed to make it a wagon.
Old 01-18-2006   #6
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
Here's an AWD 4G64 Mirage. So it has been done.
http://media.putfile.com/104_0413
Old 01-19-2006   #7
x-pride
x-pride's Avatar
Yes an all wheel drive mirage has been done. I think he is refering to the wagon which is different from a two door hatch. Which I have not seen done yet or even herd of swapping in a 4g63t.
Old 01-19-2006   #8
stikx
Mr -
doesn't happen to have a live bait shop? does it?
Old 01-19-2006   #9
SuperSleeper
They're all pretty much the same thing. The video actually wouldn't load for me... I just assumed it was a wagon. But it shouldn't make a difference.
Old 01-19-2006   #10
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Well, with those AWD Mirages and such they swapped in DSM drivetrain parts. I dont think a DSM drivetrain is interchangable with the AWD wagons. And I dont think they were made for the kind of abuse that DSM drivelines put up with.
The motor should be fairly easy to do. Every mitsu 4cyl interchanged back then. You just need the right mounts/harness etc.
Old 01-19-2006   #11
x-pride
x-pride's Avatar
I think he should just get a DSM and be done with it. When you have a sleeper people will usually brush you off. If you beat them, they will just tell you they were not really racing because you got rice. When my bro drives his spec v every mother out there wanted to race him. When he drives his Colt no one would look twice at him. Even if he revs on them they just look at him like he is stupid yes this includes hondas with noise makers. When we take out the talon the only people would look our way was v8 the rest would not ever look our way.
Old 01-19-2006   #12
1slowcolt
ive been thinking about just gettin a dsm and breing done with it. i migth but i just want something that when i do fuck with ppl around my are ( who will rev on ederly ppl) in a f*cking golf cart if theyd see'em that they just got spanked by what looks liek a total peice of shit and i already have most of the parts in a total'd dsm other wise i really wouldnt even think about it ! i jsut have most of the shit lying so why not support local law enforcement a little bit
Old 01-23-2006   #13
Actually the wagon isn't even close to a regular colt. It is a 4 door and it is MUCH bigger than a regular colt. It kinda looks like a minivan. The AWD system is push button too.
Old 01-24-2006   #14
Wizard
The AWD minivan 4G63 has been done....I've personally seen it run and here are a few links. Runs mid 12s now.
http://www.lilevo.com/miscvid/awdsummt.asf
http://www.angelfire.com/un/minivan/
http://4g61t.com/phpBB2/viewtopic.ph...fb8a8e129c6528
He's part of the KYDSM group. 2 Have been built.
Wiz
Old 01-24-2006   #15
The summit is much smaller than the colt. The colt is at least 2' longer. This is a pic of the colt that I found.
Old 01-25-2006   #16
Wizard
Dodge Colt Vista (van) or just Colt (car)= Eagle Summit = Mitsubishi Expo (Van) or Mirage (car)......same thing. The model you are showing is just an earlier model. The one in the vids was 93+.
Kinda like Talon/Eclipse/Laser......ya know?
Wiz
Old 01-25-2006   #17
That isn't really true. That is like saying a 2 dr blazer and 4 dr blazer are the same. The chassis is the same, but the wheelbase is stretched and the 4 dr is obviously bigger. Things will bolt up the same and most of the mechanicals are the same though. The weight of the bigger one is obviously going to be detrimental and I am guessing the AWD system in the newer ones is different?
Old 01-25-2006   #18
Wizard
My point was that the Colt Vita (in your picture) is the same as the Expo or the Summit Wagon.....exactly the same sans nameplates.
I never meant to say the Colt hatchback was the same as the Summit 4 dr or Mirage, etc.
Wiz
Old 01-25-2006   #19
And my point is that the Vista pictured is much bigger than the Summit wagon. They also didn't start making the Expo until 92, but that would have been the same size.
Old 01-25-2006   #20
Wizard
Wiz
