Old 01-04-2004   #1
What oil and filter are you using and why?
I was told to only use a mitsu filter by several people. Why is this??? The napa filter I have on my car is larger than the stocker. Why would we want a smaller filter? How is a mitsu oil filter better on lifter tick? I dont see how this works as it only filters the oil. Does it let more through?
Thanks in advance, John.
Old 01-04-2004   #2
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
use any filter you want. just change it when its dirty. my mitsu filters keep the oil clean about 1000 miles longer than a napa filter.
its just an oil filter :stick:
Old 01-04-2004   #3
jd1828
i did use fram filters just because they were the easiest to get. i switched to wix after i blew a hole in a fram.
Old 01-04-2004   #4
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Oil filter, what is that?
'04 Honda Ricer: stock
Old 01-04-2004   #5
Jana
Mazda Bitch
I use Napa Silver filter and Mobil 1 oil (synthetic) and change it every 3K - 3.5K miles.
Old 01-04-2004   #6
JiN
JiN's Avatar
Mitsu....just cuz.
Old 01-04-2004   #7
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Move to the Gold's, they ARE diffrent. Made by WIX. My new Grand Am has a light that turns on, it keeps track of temps, revs, milage ect. and according to other people normaly turns on in the 7k range. Oil has improved greatly since the 3k bench mark was set.
Old 01-04-2004   #8
i use napa filters and napa oil. i heard a rumor about fram filters sumtimes causing higher oil pressure. So ya, plus napa is cheap and their oil is Valvoline just sold under their name, and im all about cheap. I'm not going to start using synthetic because i heard its a bad thing to start using using synthetic on a high mile car that hasn't been using synthetic in the past. And im sure the guy who owned this thing before me didn't use synthetic by the looks of things.
Old 01-04-2004   #9
I just use a plastic bag wrapped around the hosuing.
Old 01-05-2004   #10
That reminds me, should I swap my 1g to synthetic? It has somewhere around 130k miles.
Old 01-05-2004   #11
Mobil1 oil filter
Mobil1 oil
Old 01-05-2004   #12
No. And havent we already had like 2 threads about oil and filters? I believe we have but Im not searching for it.'
Im done with mobile. It seeps right past my gaskets which are 10k miles old, now I hae to redo them all. Pan and turbo line seals.
Im going back to Castrol synthetic. With a mobil filter or mitsu.
Old 01-05-2004   #13
I remember one thread a while back but I also want to know how a stock filter sends more oil to the head (preventing/helping lifter tick). Everyone tells me to use the smaller mitsu filter than the larger napa filter. I wanted to know why.
Old 01-06-2004   #14
Its because the Mitsu filter has a better check valve in it so it helps with oil pressure. Thats the filter I use with Valvoline Full Synthetic oil. I had some lifter tick and with brand new oil in the car I put on a Wix filter and it still ticked. Then I used a Mitsu filter that Jet had at home and it almost went away totally just by changing that so it made me a believer. Its one of those times when size doesn't matter.
Old 01-06-2004   #15
OEM mitsu filter.
Mobil 1 full synthetic
why? cause everything else is junk
I like oem filters for the check valves, and if mobil is good enough for the top factory race teams, good enough for me.
Old 01-06-2004   #16
'94 Talon: Rotella-T oil with Mitsu filter
'91 Talon (beater): SuperTech (Wal-Mart's brand) oil and filter
I personally do not believe in synthetic oils...changing convention every 3k is just fine, even that is overkill to be completely honest (with normal street driving). I use Rotella since it is a heavy duty conventional oil specially designed for turbo aplications.
Old 01-06-2004   #17
The check valve in the OEM filters prevents oil from draining out of the head and back into the oil pan once you turn the engine off.
Old 01-07-2004   #18
ltdpower
Send a message via AIM to ltdpower
I know I shouldn't but right now I'm using a Penzoil filter (becuase I got it for free) And run 50/50 dino/synthetic oil, chevron supreme and mobil 1
Units
ltdpower is offline   Reply With Quote
Old 01-07-2004   #19
Raptor
ConArtist
Raptor's Avatar
Originally posted by niterydr@Jan 6 2004, 09:50 AM
OEM mitsu filter.
Exactly what I use and for the same reasons. Swanny, sometimes you are smarter than you look! :razz2:
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 01-07-2004   #20
Enes
Enes's Avatar
yeah swany i don't care what they all say about you.. i still think you are an ok guy...
LOL...
ps its slam swanny day today!!!
-E
