Old 02-01-2006   #1
dumb_ricer
Hates Everything
Drives: Neon
Quotes!
How much would it be for:
A. 2g Piston Ring set, STD bore, Turbo
B. 1g Piston Ring set, STD bore, Turbo
C. Whatevers needed for the Balance Shaft eliminator minus the bearings. Stub shaft and whatever else.
D. 7cm exhaust mani to turbo gasket
Also, what all does the Full engine gasket kit come with? Does it include head gasket, valve seals, turbo gasket, intake mani/TB gaskets, front cover gasket, front and rear main seals, cam seals, oil pan gasket, valve cover gasket? Does it include Piston Rings?
Thanks, Nathan
420A > LS1 > All Else
I > All else
Old 02-01-2006   #2
DSMPARTSGURU
Keeper of the lost toys!
Re: Quotes!
ok....
why do you need price on both 1g and 2 g ring sets??? did you need pistons??
ok on the gasket set... it comes with every gasket to seal an engine... including a 7cm if you get a 1st gen set....
what style did you need? 1st or 2nd gen??
CHRIS
Wayzata Nissan
Old 02-01-2006   #3
dumb_ricer
Hates Everything
Drives: Neon
Re: Quotes!
It is for a 6bolt 90 motor.
The reason I need a price on both 1g and 2g ring sets is because I haven't decided if I am doing 1g Big rod and 2g piston combo or just going with the 6bolt pistons yet. I can get the machining done cheap, and I think I have access to a set of pistons for cheap. Mainly just to keep my options open.
Edit: I saw the quote on pistons you gave Tauni, so no need to quote those. I think i am doing 2g pistons anyways now.
I > All else
Old 02-02-2006   #4
DSMPARTSGURU
Re: Quotes!
2G Pistons : $53.68 ea x 4
2g ring set : $123.64
bs shaft: $9.46
bs cap : $7.76
7cm gskt: $19.04
1g full gskt set: $195.86
cc
CHRIS
Wayzata Nissan
