Old 01-05-2004   #1
adam_murphy
Send a message via MSN to adam_murphy
OK:
We found a wire that was poorly connected under the coolant temp sensor that goes to the ECU. Car started perfect after connecting but then it over heated... Found a poor connection on the sensor on the radiator which fixed that problem... JET if you still have the starting problem check all the wires carefully for good connections (you probably already have).
2002 GTP - 12.9@107.5
adam_murphy is offline   Reply With Quote
