Old 02-26-2006   #1
Jerrek
91 Galant Vr4.
Hey I have a 91 galant vr4(Stock, has about 120k miles) I did a tranny swap on it and it started fine, except my radiator was also leaking so I changed that... but now it wont start.
I'm really confused here... it sparks, there's gas, the fuel system works, the ecu is plugged and grounded... I don't know what can be the problem. Cuz it started before i put the radiator in, but now I'm completely lost.
thanks,
-V
Jerrek is offline   Reply With Quote
Old 02-26-2006   #2
Re: 91 Galant Vr4.
Did you unplug any of the coolant temp sensors?
Old 02-26-2006   #3
Re: 91 Galant Vr4.
/\/\/\ I agree. If you find it is plugged in, you can use a logger to see what kind of readings you're getting too. If you get some off the wall huge number for a temp, and it is plugged in, then it could just be bad.
