Old 03-19-2006   #1
CV Shafts
Hey Chris! Can you look up two CV shafts and see if they are the same? I assume they'd have the same part numbers if they are the same.
Could you please look of a Front Passanger CV shaft for a 1991 or 1992 Galant VR4
Could look up the Front Passanger CV shaft for a 1992 Eclipse GSX.
I'm curious if they are the same...
I put that GVR4 tranny into my 92 talon that I bought from Tony, and when the CV shaft is installed there is about 1/8" play when it's in correctly. It almost seems as if the c clip was 1/8" closer to the Passanger wheel it would lock into place correctly. I just want to see if there is any difference in the axels, if not, that means the front diff is f-ed.
Thanks!
Kevin Swalchick.
