Old 04-04-2006   #1
DSM_421
1st gear help
I have a feeling that my syncro (sp?) for my first gear is shot, because it isn't slowing the gear down when I put it in gear, it will actually grind unless i shift into second and then back into first. So at stop lights I have to put the clutch in, put it into second gear and then back into first before I can go, gets a little annoying after a while...
It also will grind, or what seems to be a grind going from first into second after the car has been sitting turned off for a while. But after that intial "grind" it makes going into second from first, it won't happen again until I turn my car off and drive it again a few hours later.
Thanks for any help in advanced!
Old 04-04-2006   #2
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Re: 1st gear help
Rebuild time!
-Colin
Old 04-04-2006   #3
Re: 1st gear help
Do you have some decent/newer fluid in there? It may be time for a dose of Redline.
Old 04-04-2006   #4
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Re: 1st gear help
You will just be prolonging the problem.
-Colin
Old 04-04-2006   #5
Re: 1st gear help
Not necessarily, the fluid may just be THAT bad. Otherwise, even if you get another summer's use out of the tranny with $24 in fluid its worth it, especially considering many DSM's as a whole don't make it that long!
Old 04-04-2006   #6
DSM_421
Re: 1st gear help
Rebuild time!
-Colin
That is what I figured. Tranny has 98k on it. I don't really want to just bring this in and have it rebuilt thought, I'd rather be able to do it my self.
Problem is, I am still in the learning proccess and would need to find someone who one knows what they are doing, and two would want to actually help me.
Old 04-04-2006   #7
DSM_421
Re: 1st gear help
Thanks, I'll probably do this for the time being, until I have the funds to start on rebuilding it.
Old 04-04-2006   #8
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Re: 1st gear help
royal purple 75 / 90 I think is the GL4 fluid you'd need. I'd recommend this over redline from my experiences. Redline works great with new trannies, but for some reason royal purple seems to "restore life" to older trannies a little more effectively than redline. That's just my .02
- Josh L.P.
Old 04-04-2006   #9
KcGsXrated
KcGsXrated's Avatar
Drives: 93 Talon Tsi
Send a message via AIM to KcGsXrated
Re: 1st gear help
I agree, i put regular tranny fluid in my buddies car and whenm he had the money and time to do it, put in royal purple and its a night and day difference.
~~DSK~~
Casey
93 Eagle talon Tsi fwd auto
KcGsXrated is offline   Reply With Quote
Old 04-04-2006   #10
GVR-4579
Re: 1st gear help
you might want to check the clutch out a bit too, just check that it is properly disengaging. If you have any questions on the rebuild let me know when you get there
