Old 04-26-2006   #1
NEED HELP ASAP!!!!! Crank Pin.
I bought a new crank and when I went to put on my flywheel I noticed that there was no pin in it to hold the flywheel in place. Can I run without the pin? Let me know.
Thanks,
Mike
Old 04-26-2006   #2
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Re: NEED HELP ASAP!!!!! Crank Pin.
pin...? Are you refering to the dowel? If you are, I'm pretty sure you need that to keep the flywheel perfectly centered. If you are talking about something else, I'm not sure what you are talking about!
- Josh L.P.
Old 04-26-2006   #3
Yes the dowel in the crank that keeps the flywheel centered.
Old 04-27-2006   #4
Anyone???????
Old 04-27-2006   #5
Im sure the Mitsubishi engineers put it there for a reason... I can't see how you'd die, or the world would end, if you installed it without the pin. I swear there is a machined ring the fhywheel sits on, and the there isn't much clearance with the bolt holes. If you can get me the dimensions of the dowel pin, I can either make you one or take one from school.
Old 04-27-2006   #6
GVR-4579
yea there is a machined ring, i know more than a few cars that dont have one right now, it is mostly so idiots dont put the flywheel on wrong, but as far as i know dsm's can only go on one way anyways, i personally wouldnt worry about it.
Old 04-27-2006   #7
So, I dont need it and its just for easy install of the flywheel. In that case Ill just throw the tranny on.
Old 04-27-2006   #8
GVR-4579
thatas what i would do, just make sure the dowel pin space is lined up, but i dont think it will bolt up if its wrong
