Old 05-09-2006   #1
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
installing a big 16g
I already have a big 16g, but I'm taking that out and replacing it with a new one. I know I will have to drain the coolant and the oil. Will i have to replace any lines or tubes? My thought is that it will bolt right up to what I've got now since it's the same turbo. <-Is that correct?
Also, any hints or tips would be much appreciated!
Old 05-09-2006   #2
Re: installing a big 16g
Just get all new gaskets and crush-washers for everything along with 4 new manifold/turbo bolts.
Old 05-10-2006   #3
HiImBrian
HiImBrian's Avatar
We finished putting in the turbo at about 1:00 last night. Everything went prettys smooth except when we added coolant. There is a pipe that goes into the back/bottom of the turbo that takes two 10mm bolts and a gasket. We bolted it up as tight as we could, but it leaked coolant when we were all done. I went in to tighten the bolt a little and it broke in half. so right now the car is still up on jacks and the pipe is disconected. Is there anything i can do about that broken bolt (half of it is in the turbo!)?
HELP!
Old 05-10-2006   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
you could try using an easy out to get it out. Other than that, you might have to try and drill and tap it again.
7/25/09
Old 05-10-2006   #5
HiImBrian
HiImBrian's Avatar
whats an easy out?
Old 05-10-2006   #6
Onefast99gsx
An easy out looks similar to a tap. You drill a hole in the center of the stud that is broke off. Then you screw in the easy out into that hole. They have a reverse thread so it automatically tightens itself when you attempt to back out the broken stud.
Old 05-10-2006   #7
HiImBrian
HiImBrian's Avatar
Are there different sizes? Because the bolt that broke is a 10mm so I would need somthing smaller right? Where can i get an easy out? napa? checkers?
Old 05-10-2006   #8
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
you can get an easy out at just about any hardware store. Yes, you wnat something smaller.
7/25/09
Old 05-10-2006   #9
HiImBrian
HiImBrian's Avatar
Ok thanks! I'll get one tonight and try it out on this friday.
Old 05-13-2006   #10
HiImBrian
HiImBrian's Avatar
So I tried to use the "easy out" and it turned out to be more of a "hard/impossible out." I guess the bolt was cross threaded somehow, so we crossed our fingers and drilled it out and taped it. Everything turned out perfect luckly! So tomorrow I'm off to the hardware store to get a bolt and then the whole new turbo goes in!!! This whole process took way too long.
pics or gtfo
Old 05-14-2006   #11
HiImBrian
HiImBrian's Avatar
After stipping the threads on the newly tapped hole we decided to use some PVT heat sealant. Let it dry over night and it held like a charm. I went for a little test drive this morning and it rides beautifully. Now all i need is new injectors.
pics or gtfo
