Old 05-11-2006   #1
SAFC II Not Right...
I put in my SAFCII in this winter and when I finally got my car working I noticed that the RPM is WAY off. When my tach says im going at 2500 RPMs the SAFCII says 1500 RPMs. And when Im idle at like 1000 RPMs it was like 500-600 RPMs. Did I do something wrong? Im almost 100% sure I hooked the right wires up and connected it with solder.
Mike
Old 05-11-2006   #2
Re: SAFC II Not Right...
You probably have a setting in the AFC wrong. Re-check your settings.
Old 05-11-2006   #3
Maybe thats my prob, I didnt even know there were different settings. Ill go check it out. Thanks.
Old 05-11-2006   #4
SLOW_V
Make sure your cylinder select is two and not four or your tach will double.
SLOW_V is offline   Reply With Quote
Old 05-11-2006   #5
Im a Dumbass, It was actually on 6 and I just turned it to 4 and It like 100 RPMs off not so its all good(I didnt even know that setting was there). But what about the little arrow next to it. you can have it pointing up/right, down/right, or nothing. What is that sapose to be set at
Old 05-11-2006   #6
SLOW_V
Check the afc manual it will show you how to set that arrow. I forgot how mine was set up but than I have a 1G.
Old 05-11-2006   #7
Alright got that figured out. Is there anyother setting I should have made?
Old 05-11-2006   #8
x-pride
x-pride's Avatar
What size of injectors are you running?
Old 05-11-2006   #9
S-AFC instructions:
4 cylinder type arrow up towards the right (that is throttle setting).
Karmen vortex meter type
high/low throttle points usually around 25%, 75%
No december air settings.
That is all I remember off the top of my head. If your tach is off by about 100 or so rpm, its your gauge, not the s-afc.
Old 05-12-2006   #10
Im running 650s but my MAFT already compinsates for those.
