Old 05-14-2006   #1
2fst4u
boost ??
I have a 90 laser RS turbo 14b, 255lph, safc1, removed b-shaft, and boost controler. I am curently running 14psi. everything was working fine(spooled up to 14psi around 4000rpm to red line) but now I am having a problem with staying at 14psi.if I get on the gas the car reaches max boost at 4000 then at about 5000 drops to 10psi and trys to go back to 14?? why is it going to 14psi then droping to 10psi and then try to spool up again to 14???any ideas
Chris
2fst4u is offline   Reply With Quote
Old 05-14-2006   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: boost ??
Check for boost leaks. 4000 rpm's seems a little late to me my scm-61 makes almost 20 psi by 4000.
11.35 @ 120mph
Old 05-14-2006   #3
Re: boost ??
Boost leak or BOV opening?
Old 05-15-2006   #4
Re: boost ??
Enough. Check for boost leaks first and then post results and we will go from there.
Old 06-01-2006   #5
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
Send a message via AIM to joesushi
Re: boost ??
Do you have the boost leak tester kit? It consists of a quiet well lit garage, rubber cap with bike valve on the end to go over compressor inlet, A squirt bottle with soapy water, and a compressor with the air valve fitting to pressurize the system. Works all the time. If you need help building one, berda and i made one in about 30 min. Fleet farm, napa, and home depot will have all you need.
A 4 inch long piece of 2.5" O.D. (outside diameter) hose. (I used some radiator hose I got at NAPA)
1.5" I.D. (inside diameter) PVC end cap.
2 band clamps that will fit around the 2.5" pipe above.
A valve stem (I used the rubber type you press in)
With this you can get a rough idea on what you need. I would recommend using the valve stems that bolt in, they dont leak for sure. Eliminate one leak at a time.
On the same topic, I did a test on our galant vr4, I found 4 major leaks in the first 5 minutes. It's really worth it. The last major leak i cant fix is a leak by the isc motor, Its a massive leak and i cant build up more than 6 psi, it just whistles and howls loudly, and when i spray the soapy water down there instantaneously huge bubbles appear. This is on the throttle body. Any ideas?
out-running the velocichoppa! in my dsm.
joesushi is offline   Reply With Quote
Old 06-02-2006   #6
tsigurl1991_rx
Mentally Retarded
tsigurl1991_rx's Avatar
Drives: 1996 egale talon TSI AWD GREEN for now
Send a message via Yahoo to tsigurl1991_rx
Re: boost ??
Yes there are many reason's why it could be doing that. My egal talon TSI did the same thing exccept at 17psi and then to 12psi and it ended up being a boost leake. Listen to the guys they know what there talking about.
Ladyrage 1996
tsigurl1991_rx is offline   Reply With Quote
Old 06-02-2006   #7
Thor06
11 Seconds to Freedom
Thor06's Avatar
Re: boost ??
Boost spike doesnt have anything to do with boost leaks does it?
Thanks for the boost leak tester instructions, I am going to go make one in about a half hour and see if thats maybe why my buddies car isnt starting.
Old 06-02-2006   #8
Re: boost ??
No. If you have boost spikes it will jump up high and then settle down right after boost comes on. Boost creep is went the boost climbs the higher the RPMs go (usually because of small wastegates and to free flowing of exhaust).
A boost leak would probably not make the car not start. Unless you have a intercooler pipe totally off it should start. It will most like even run with a intercooler pipe off, it just wouldn't go anywhere if you were using a stock MAF.
Either way a boost leak check is a bad idea but I think the starting issue you speak of is something else entirely.
Old 06-08-2006   #9
2fst4u
Re: boost ??
I just go back in town....and I did check for boost leaks and found none! their was no boost leaks at all...So I drove my car for about another 500mile and now blue smoke is pouring out the exhaust and my turbo is fried:-( o well time for a 16g
Chris
Old 06-08-2006   #10
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
Re: boost ??
Hey mines going too! lol it sucks!
Tyler Aherns
-USN-
