Old 05-17-2006   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Building a manual boost controler
Has anyone ever tried this and made it work? I am trying to make one. I bought a 1/4" ball barring and was at a hardware looking at the brass fittings. I found a brass T and on the package it said It had an ID of ¼” but when I put the ball barring in, it had way too much space between the fitting and the ball or that’s what it seemed like to me. Just curious if anyone has gotten this to work. Thanks!
Old 05-18-2006   #2
Andrew7dg
Andrew7dg's Avatar
Re: Building a manual boost controler
Just realized that it would probably help if I showed everyone what I am trying to build
http://www.geocities.com/chmwatson/FAQs/mbc.html
Old 05-18-2006   #3
Try filling it with RTV.
Old 05-18-2006   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
My brother made one and it works perfectly. He used something different than an allen head to turn it in and out though so it could be done by hand.
7/25/09
Old 05-21-2006   #5
Andrew7dg
Andrew7dg's Avatar
Just out of curiosity where did he get the parts for his? Or what parts did he use? I went to the hardware store and they didn't carry those specific parts.
Old 05-22-2006   #6
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
He works at an ace hardware and just grabbed them off the shelf. I am not sure what exact parts he used though. He isn't on here much anymore.
James
7/25/09
Old 05-22-2006   #7
But from the looks of it the ball never sees the inside of the T fitting but it sits in the nipple fitting which would be smaller then the t fitting. And all its doing is plugging the little hole so that its harder for the boost to get throught to the WG.
Old 05-22-2006   #8
Andrew7dg
Andrew7dg's Avatar
Ok so that makes more sense. For some Odd reason I thought the ball had to clear the other opening. So really I don't have to worry about the space around the ball and making sure it is a tight fit. THANKS!!
I will go to a hartware store soon and try this out with this in mind.
Old 05-22-2006   #9
I too have considered machining my own MBC, from scratch, for the fun of it. The only thing I couldn't make would be the ball bearing.
Old 05-22-2006   #10
Andrew7dg
Andrew7dg's Avatar
a whole $.10 at a bicycle store
Old 05-22-2006   #11
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
My brother got everything from his work so I assume just about any ace will have the parts needed. The one I am using worked fine with no spike issues or anything.
7/25/09
Old 05-26-2006   #12
piss
Send a message via AIM to piss
some guy in MN sells nice ones for 12.95 shipped (hes way up north) found em on ebay there pretty nice. i was gona build my own too untill i found that for probly about the same as the parts would cost me and i wouldnt have to try and drill and tap shit
piss is offline   Reply With Quote
Old 05-26-2006   #13
Bunta
Bunta's Avatar
You can buy the one me and my friend made for $10. We got the parts from ACE hardware.
Bunta is offline   Reply With Quote
Old 05-27-2006   #14
Eh I just want to literally make one so I can have a nice for near free. And say I made it.
Old 06-10-2006   #15
Andrew7dg
Andrew7dg's Avatar
Ok I built one finaly I am trying to figure out where to mount it in the engine bay. I will get a picture of it soon. The one problem is that once in a while it will have a boost spike. I have it set at 10psi but every once in a while it creeps up to 12 then back down, that is what is called a boost spike right? How do i fix this?
I think though I need to find a different spring though. This one is kind of touchy.
Anyway it is a lot cheeper then buying one.
BTW everything is stock on the car (for now anyway) 10 psi is a safe setting on it right now right?
Old 06-10-2006   #16
10PSI is what you car should runs stock.
