Old 05-23-2006   #1
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Launching!!
So what are the best ways people launch there awd dsm off the line? Best way without ruining things. Just wanting to here what you guys and gals have to say, Thanks ~jeremiah~
Finally tuned and fully built, Takes a lot of time,patience and money!!
96 Gsx Awd is offline   Reply With Quote
Old 05-23-2006   #2
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: Launching!!
...just letting you know..launching is the worst thing that kills dsm trannie's and their drivelines. BUT, it's just too fun.. I hear people holding it at about 5500 rpm, and letting the cluthc out JUST enough to start grabbing..when the light turns green, less reaction getting off the clutch, and stomp on the gas..not fully though..ya gotta slip it just a bit so you don't bog the launch, or spin too much (yes, street tires awd spins). it's a feel kinda thing..go out n try a few times in a safe area..
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 05-23-2006   #3
GVR-4579
Re: Launching!!
+1 on the getting the clutch to the dragging point before taking off, it keeps everything from slamming together and takes some of the stress out of the launch, it is still hard on everything tho
my proceedure is: put car in gear, bring car to desired RPM, let clutch slowly out to friction point(where it just tries to move), then when you are ready to go quickly release pedal but not too fast or you will spin/bog too much.
Old 05-23-2006   #4
JiggahMan
Re: Launching!!
Before I use to hold it at 4500 and let the clutch pretty quickly while flooring it. Recently I've been playing around with stutterbox and a 6000rpm launch is pretty fun... So is broken driveline lol.
JiggahMan is offline   Reply With Quote
Old 05-23-2006   #5
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Launching!!
I used to pre-load the cluth slightly and bounce the rev's between 5000 to 5500. When I finally launch I try and slip the clutch as the revs are coming up (kind of hard to explain it). I found without a stutterbox if you bounce the rev's with your accellerator pedal and launch as the rev's are coming up it builds boost better than if you hold it at a set RPM and slip it. That's how I got my pretty much stock Talon to run it's 12.99.
Then again it all could just be in my head
Old 05-24-2006   #6
GVR-4579
Re: Launching!!
not in your head, bouncing the rpm's without a stutterbox will build boost
Old 05-24-2006   #7
96 Gsx Awd
96 Gsx Awd's Avatar
Re: Launching!!
Is a stutter box were the rpms just go up and go to a certain point and stays there? (sorry hard to explain)
Old 05-25-2006   #8
GVR-4579
Re: Launching!!
yea, a stutterbox is like a rev limiter that turns off with the clutch pedal. i love mine it takes one more thing off your mind you need to concentrate on when launching, you can just hold it floored and have any rpm you want without trying
Old 05-25-2006   #9
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: Launching!!
You could always just hold the throttle at around 2k and just floor it when you are supposed to go, slipping it when it is at the desired launch rpm. It wouldn't be to consistent, but would help you get off the line quick if you were new to it. Everyone has their own method. That way seemed to work pretty well for me before I had a studderbox. I just did that and launched between 4500 and 5000 rpm.
7/25/09
Old 05-25-2006   #10
Re: Launching!!
It is a terrible idea to just rev it up to 6K and DUMP the clutch. But it makes for a fun launch.
Old 05-25-2006   #11
Steeltwo
CompUSA Whore
Drives: 07 Civic Si, 06 IS 350 and I own a dsm
Send a message via ICQ to Steeltwo
Re: Launching!!
watch Shep launch his dsm.
he rolls it and drops the hammer.
i did that for 3 years and my clutch finally started to slip this past winter. But what is odd, the clutch doesn't slip anymore and hasn't since I got it out of storage.
91 tsi awd
07 Civic Si
06 IS 350
Steeltwo is offline   Reply With Quote
Old 05-25-2006   #12
Re: Launching!!
I 100% disagree. I did that probably 40+ times over a couples months time (15+ in one afternoon) on my old 95 GSX with a ACT 2600 and I never had a problem. This was on the T25 pulling low 1.7 60' foots running 13.4 - 13.6. The car hit VERY hard out of the hole each time, to little to late by 1/8 mile with the T25
If the car holds up, give'er hell!
Old 05-25-2006   #13
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Re: Launching!!
I've always launched around 4.5k-5k rpm. Slip it just enough to catch and then floor it almost at the same time and let the clutch fully grab. It worked for me on my ACT 2100, but not so well on my ACT 2600. Maybe I'll try dumping at 6k once and see how that goes. I bogged when I tried dumping at 5.5k though . My car must just be too weak, eh?
Old 05-25-2006   #14
Steeltwo
CompUSA Whore
Re: Launching!!
a stutterbox makes the process ALOT easier.
91 tsi awd
07 Civic Si
06 IS 350
Old 05-25-2006   #15
DSM_421
Re: Launching!!
I've had success anywhere from 5,000 to 6,500 rpms. I tend to like 5,500 rpms the best because then it seems to be the perfect launch for my set up, it doesn't squeel the tires, and it doesn't bog at all. She just gits up and go and the rpms just climb from 5,500 and never go down after releasing the clutch.
Basically what I do is rev her to 5,000 and when I know the lights about to go, I let the clutch out just enough for the car to start to roll a little, then i give it more gas so that she revs to 5,500 and starts building boost, then the light turns and I let the clutch out slow enough without burning it and punch the gas and next thing I know I'm going 30 mph shifting into 2nd.
Old 05-25-2006   #16
Re: Launching!!
Ok this is kinda Noob, but the DSMLink has a built in studderbox right? I have my launching rpms set at 3200
Old 05-25-2006   #17
SlowWhite
Been there, done that.
SlowWhite's Avatar
Re: Launching!!
Stutter Box launch is 7Krpms at about 12-15psi of boost at launch. And I just dump the clutch. at least 50+ passes run that way with out tranny problems. Wasn't until I lowered my launch rpms to the point where my tires grabbed and then wheel hopped like crazy. That's when I broke my tranny.
Basically IMO it's better to either launch gently (ie: roll into it) or launch hard (ie: make damn sure your tires break loose and are spinning) Both ways should yeild you less tranny breakage.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 05-25-2006   #18
Swifty1638
Swifty1638's Avatar
Re: Launching!!
...and, if you launch hard, have a clutch that will take it..honestly, twin discs are the best, and they are not THAT unstreetable..
-A. Swift
Black 1GB Mafia #1
I wanna go fast.
Old 05-25-2006   #19
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Launching!!
I just recently tried brake boosting (w/ a 5spd) and let me tell you it makes a major difference!
I have my stutter box set to 6500rpms, while at the lines staging, press the brake with the left side of your right foot and press the gas with the right side of the same foot. Then slip the clutch until you feel it start to grab and bring it up to the stutter box. It helps a lot bringing up boost on larger turbos like mine.
I've also heard of people doing the same thing and also grinding the first 4-5 teeth (notches) on the e-brake handle and pull that when they are staging. Then all they have to do is let go of it and it drops on its own allowing the e-brake to release. I'm going to be trying this very shortly!
Originally Posted by shoutbox
Old 05-25-2006   #20
Gravy
Who's this guy?
Re: Launching!!
Febo and i went through a clutch in a month doing 4k launches. I think he slipped it out way to slow though, cause you'd always smell burnt clutch for about 10 minutes after a launch.
