Old 06-22-2006   #1
snea
Antifreeze in my intake?!?
I replaced the turbo a few months ago and it was, by one way or another, ingesting COOLANT... Sorry, I'll stop my rant...
I have a 95 Talon Tsi AWD. I bought this car from a "friend" about six months ago. He had spun the turbo, and that is all I knew. I found a used turbo that I bought and installed. When I started it, it was burning coolant at the rate of about a quarter to a half gallon a minute. I did a leakdown test, it gave all the sighns of having a cracked block and I was 95% sure of it. So I set it aside for spring planting season.
I've finaly had the chance to start tearing things apart, and I find fresh, clean coolant in my upper intake hose. Despite working on the farm for many years and having a basic knowledge of mechanics(about as good as my brother who is a john deere technition), I am completely stumped.
Please help me.
snea is offline   Reply With Quote
Old 06-22-2006   #2
Thor06
11 Seconds to Freedom
Thor06's Avatar
Re: Antifreeze in my intake?!?
Sounds like a leaky seal in the turbo.
Old 06-22-2006   #3
snea
Leaky seal? I didn't think the casting, uness cracked, would allow for coolant to leak...
Old 06-22-2006   #4
Boostin_dreams
Send a message via AIM to Boostin_dreams
Well what in the leakdown test showed that it would be a cracked block? Need to know what the tests you did showed and what test you did to help you out more.
Boostin_dreams is offline   Reply With Quote
Old 06-22-2006   #5
tim
tim's Avatar
Yes, what are the results of the leakdown and where was it leaking from? Also, have you done a coolant system pressure test? If not now would be a good time.
Old 06-22-2006   #6
snea
when I did the leakdown test, I heard air coming out the coolant fill hole, and none out the oil filler hole.
When it ran, it would spew acers of white smoke, and after test driving it, there was antifreeze in the oil.
Old 06-22-2006   #7
snea
I just broke the seals on the coolant system, I was getting ready to take off my head.
Old 06-23-2006   #8
Shane55113
Now 20% less Racist
Shane55113's Avatar
time for a 6bolt
Old 06-23-2006   #9
snea
Originally Posted by Shane55113
time for a 6bolt
I wish guys, but I can't afford it, that's why I was going to part it out, but now I found this, I thought it may be a different problem than I expected.
Oh, and when I took the sparkplug nearest the trans out, the piston was wet, and that's the cyl. that leaked through the coolant system.
Old 06-23-2006   #10
So it sounds like a blown head gasket.
Old 06-23-2006   #11
snea
So should I still try to pull the head off? I still have the intake and exhaust maifold attatched...
