Old 07-08-2006   #1
Enes
Enes's Avatar
Headlights harness melting
Ok, this is beginging to piss me off.
this is 3rd melted headlight plug...
i put factory lightbulbs back in so they are the crappy yellow weak ones.
yet the plugs keep geting melted, the plastic right next to the contact gets all melted and burned out.
Does anyone have any suggestions?
Old 07-08-2006   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Headlights harness melting
when i did my H4 conversion. I bought aftermarket plugs that where suposed to be more heat resistand. you could try that.
11.35 @ 120mph
Old 07-08-2006   #3
Wierd. I had the same problem in my Galant when I put in Silverstars, and just putting in cheapo headlights fixed it for me.
Old 07-08-2006   #4
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
It's a very common problem with newer Mitsu's. Did you replace them with the O.E. pigtail harness?
Old 07-08-2006   #5
Enes
Enes's Avatar
i went to junk yard and got some used old ones..
where can i get these conversions, and how much work does it require?
Old 07-08-2006   #6
I went to mitsu and bought new pigtail harnesses. The wires seemed like a thicker guage. With the new harnesses, and the cheapo bulbs, I'm having no more problems.
Old 07-08-2006   #7
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Yeah, they did update the harnesses with a little heavier duty ones. If I was you Enes I would go buy the pigtail harnesses from Mitsu and solder those bad boys up.
Old 07-08-2006   #8
Enes
Enes's Avatar
are parts open on saturday?
Old 07-08-2006   #9
I don't think so.
Old 07-08-2006   #10
carltalon
carltalon's Avatar
I got mine on ebay. they look good and I havent had any problems yet. http://cgi.ebay.com/ebaymotors/ws/eB...category=42613
11.35 @ 120mph
Old 07-08-2006   #11
Enes
Enes's Avatar
do the bulbs mount in the same way into the housing? or did you have to do some work on the headlights to put the H4 bulbs in
Old 07-08-2006   #12
Enes
Enes's Avatar
I will most definetely go with that.. i don't want to be modifying the housing at all..
Old 07-08-2006   #13
Enes
Enes's Avatar
Depending on how much work is needed to get this working on a 2g, has anyone else done this upgrade on a 2g?
Old 07-08-2006   #14
carltalon
carltalon's Avatar
I bought H4 upgrade housings to replace my pop-up sealed beams from checker. I'm not shure how the 2g headlights work but I think you might be able to just get bulbs and the harnesses I got. The ones I got are the best lights Ive seen other then HID's.
11.35 @ 120mph
