Old 07-20-2006   #1
95tsi
95tsi's Avatar
Drives: a pos
Tranny
Just got my tranny back from Shep today. Time to install it and finally drive my car again!!!!
Old 07-20-2006   #2
Black97civic
35mpg
Re: Tranny
word?
Old 07-20-2006   #3
9guy9
Dumb and...........
Re: Tranny
Nice, I just installed my Shep tranny in June and have been happy with it. Other than the welded center diff
My car will be faster tomorrow.
9guy9 is offline   Reply With Quote
Old 07-21-2006   #4
95tsi
95tsi's Avatar
Drives: a pos
Re: Tranny
Well, the install went smooth. The tranny and everything is back into the car. Started it up and ran fine. Took it for a drive and cant get it into 5th gear. Just seems to stop, like somthing is in the way.
I took the shift cables off in case it was somthing stupid such as they short shifter not getting to the right spot. But, same thing, wont go into 5th gear. This is wierd since I sent Shep the tranny with it stuck in 5th gear. Now I cant seem to get it into 5th gear... ??? Any ideas?
Old 07-21-2006   #5
Turbocharged
Re: Tranny
Did you check the linkage at the transmission as well?
2.4L g4cs, 8.8:1 compression, arp hardware, eagle rods, wiseco pistons, 50 trim, TRE transmission, SBR 3500, 880's, DSMlink, methanol injection, FP2 cams, ported 1g head, spearco FMIC, walbro 255, ect.
Turbocharged is offline   Reply With Quote
Old 07-21-2006   #6
95tsi
95tsi's Avatar
Drives: a pos
Re: Tranny
Yea, tried to shift it by hand right at the transmission without any cables on it. Did the same thing as with the cable attached. Still wont go.
Old 07-25-2006   #7
Turbocharged
Re: Tranny
Have you figured out what is wrong? Have you contacted shep? I have only heard good things about his transmissions so this is surprising.
Old 07-25-2006   #8
Re: Tranny
He will stand behind his work. If you SERIOUSLY can not shift it by hand (cables detached, grabbing the levers on the tranny and moving them by hand) give him a call. Make sure you're moving the correct levers in the correct direction. I personally hate being told something I did doesn't work when it's actually just fine.
Old 07-25-2006   #9
95tsi
95tsi's Avatar
Drives: a pos
Re: Tranny
As luck would have it, the reverse light switch was screwed on too tight. So, after loosening it up a bit everything seems to work fine. Just need to go through the break in period for the tranny and flywheel and I should be good.
