Old 07-22-2006   #1
TurboDomestics
TurboDomestics's Avatar
Coolant coming out my exhaust.
Theres a lot of coolant coming out of my 95 gst I just acquired.
I got it with no turbo hooked up, so I bought a 14b from Jet, and put it on using a 14b install kit that came with the car.
And now theres ALOT of coolant coming out of the exhaust.
Initially I thought it was the head gasket, but I tested the compression and it came out to be, 170-165-170-170, so the headgasket should be ok.
Now is the turbo no good? It has absolutly no shaft play, but I did put on a new exhaust housing before installing it. Of did I mess up installing the lines for the coolant to the turbo?
Any help would be much appreciated!
thanks alot!
-Charlie
4G63 0, Charlie 3
Old 07-23-2006   #2
Re: Coolant coming out my exhaust.
What ended up being the problem? I saw you posted that the turbo was good.
Old 08-02-2006   #3
96_Tsi_AWD
96_Tsi_AWD's Avatar
i'd also like to see what happened... i'm having the same issue.
can you post what the problem was?
Levi
96 TSi AWd
96_Tsi_AWD is offline   Reply With Quote
