Old 08-03-2006   #1
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Unhappy Coolant problem...
Ok, just installed the 50-trim after denting the pipe, plugging the banjo bolt and now...
It is leaking coolant right where (I believe) the water pipe connects with the water pump (right above the alternator). Is there any quick solutions...like...metal sealant or something? Or is it necessary to have the water pump redone? Or an alternative???
Guys, your input is REALLY appreciated!!!
Old 08-03-2006   #2
x-pride
x-pride's Avatar
Re: Coolant problem...
You did put the o ring back on the water pipe right? Another stupid question what year is your car?
Old 08-03-2006   #3
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Actually, I didn't even take off the big water pipe.
2g btw.
Old 08-03-2006   #4
O-ring at pipe/coolant pump.
Old 08-04-2006   #5
Turbocharged
There is one bolt holding the pipe onto the block. Remove that bolt and pull the pipe out of the water pump. Replace the o-ring on the pipe and lightly coat with sil-glide or dielectric grease.
2.4L g4cs, 8.8:1 compression, arp hardware, eagle rods, wiseco pistons, 50 trim, TRE transmission, SBR 3500, 880's, DSMlink, methanol injection, FP2 cams, ported 1g head, spearco FMIC, walbro 255, ect.
Turbocharged is offline   Reply With Quote
Old 08-05-2006   #6
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
thanks...will keep you guys informed.
