Old 08-04-2006   #1
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Stock gauge cluster
I've been toying around for a while about replacing all of the stock gauges (speedo, tach, oil psi, water temp, fuel level) with some autometer ultra lite ones, to match my current setup. But, I am not quite sure what size to use. I'd assume you cut the stock cluster up, with the current holes just bored out, and you fit in the autometer gauges. Problem I see is that the tach and speedo seem to be wider then they are tall. Making it kinda ob-long. I can see the smaller 2 1/4" series of gauges working, but what about the tach n speedo? Also, can I cut all the way through, not worrying about the green electronic board behind it, or will I run into issues there? I assume so, because the sensors and warning lights all use that green "motherboard" too. Anyone else ever do this?
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
