Old 08-08-2006   #1
Where Can I Get A Bung?
I need a weldable bung for my IAT sensor. 3/8npt. Anyone know where I can get one?
Old 08-08-2006   #2
Re: Where Can I Get A Bung?
(local place)
Old 08-08-2006   #3
I think I got mine at an Ace hardware store.
Old 08-08-2006   #4
94talonawd
94talonawd's Avatar
Yea. Just take your o2 sensor, and bring over to the hardware store and match up the threads on a bolt. Then just weld that on. =D
SOLD
94 Talon AWD
Big 16G
SAFC-II
12.3@114, 1.81 60ft
-On it's way to 11's....
Old 08-08-2006   #5
There are a few problems with that. It is for an IAT sensor, not an O2 sensor and a bolt isn't going to work well for a bung. I am guessing you meant a nut, but that won't work for an NPT thread.
Old 08-09-2006   #6
What did you buy jet? do they sell bungs or did u get something else that worked. Also if you remember what part of the store was it in(plumbing?)?
Old 08-09-2006   #7
Yeah, plumbing and I got a piece that had a female 3/8" NPT end on it, then cut it off and used that.
Old 08-09-2006   #8
Do they have aluminum? Because Its being welded to the TB elbo so Im assuming you cant weld steel to aluminum(correct?).
Old 08-09-2006   #9
I doubt they will have aluminum. I put mine in the UICP right before the elbow, then it is stainless and can be welded.
Old 08-09-2006   #10
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
I think I have an aluminum bung somewhere. If you want a steel one, you can get a steel bung from the hardware store and cut it in half. It'll probably be galvanized steel though. I believe the thread is 3/8 NPT.
'04 Honda Ricer: stock
Old 08-18-2006   #11
You are going to want that in the upper IC pipe not the TB elbo. Heat soak from the manifold/ head will/could make your IAT read higher then the air temp in the pipe. I think we have one at the shop, or we do have a lot of the SS weld in bungs.
