Old 08-11-2006   #1
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Thumbs up I have some important questions please help??
Ok well my first question is if i have a 7bolt head with a 6bolt block which gasket set should i get?? My other question is i have a 7bolt flywheel and 2600 clutch, i was told i could use the clutch but you have to get a 6bolt flywheel. Is this true? the source was pretty reliable he helped me out with a lot of other things. How much power does it take away from using this set up a 7bolt head and 6bolt block? i heard you loose power this way, but the head and block are ported and bored. Thanks for the help guys.
Finally tuned and fully built, Takes a lot of time,patience and money!!
96 Gsx Awd is offline   Reply With Quote
Old 08-11-2006   #2
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Re: I have some important questions please help??
If you have a 6 bolt block you need a 6 bolt flywheel. It has nothing to do with the clutch.
Old 08-11-2006   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Yes like CVD said, you need a 6 bolt flywheel.
6 bolt and 7 bolt head gaskets are the same. Depending on what year head you have, it could be just as good as any 6 bolt head. If it is from a 95-99 then it will have smaller intake ports which can be better for spooling smaller turbos.
(Dont forget to have the head drilled out to fit the larger head studs)
You also need to keep the 2g starter plate that bolts to the block behind the flywheel. Take it off of your 7 bolt block and bolt it to the 6 bolt block.
Originally Posted by shoutbox
Old 08-11-2006   #4
96 Gsx Awd
96 Gsx Awd's Avatar
Thats what i thought thanks a lot
Old 08-11-2006   #5
96 Gsx Awd
96 Gsx Awd's Avatar
Talking Re: I have some important questions please help??
Thanks for answering the head gasket question, i did know all the rest about the starter and getting the head drilled out one size bigger but thanks for all the info appriciate all i can get from anyone.....
Old 08-12-2006   #6
96 Gsx Awd
96 Gsx Awd's Avatar
Is there anything else i should know guys? Thanks
