Old 08-12-2006   #1
tnm27
I'm the short one.
tnm27's Avatar
Cars acting wierd...dunno what it is?
alright so here's where my car lies. i have a 91 eclipse gsx. just rebuild the motor about 2 months ago. at first when you start the engine it goes to 2000 rpm and than starts to idle after about a min. than the check engine light goes on. today i relieved the fuel pressure system so i can take my fuel filter out. just being curious i decieded to replug everything in, after that the car just wouldn't start. it doesn't crank or anything. the starter clicks but nothing else, the battery is still alive as well. i dunno what it could be. i had this problem before but i put a new ecu in and it started but i don't know what it is this time. another quick question is that my headlights don't flip down for some reason, the lights were up when i bought it but it won't go down. any advice would be appreciated. thanks.
tnm27 is offline   Reply With Quote
Old 08-12-2006   #2
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Re: Cars acting wierd...dunno what it is?
If you can get it started again let it run and disconnect the negative on the battery, if your car dies you need a new alternator, if it stays running your good. Try charging you battery and then try this.
Finally tuned and fully built, Takes a lot of time,patience and money!!
96 Gsx Awd is offline   Reply With Quote
Old 08-12-2006   #3
94talonawd
94talonawd's Avatar
That is a really vague question.
SOLD
94 Talon AWD
Big 16G
SAFC-II
12.3@114, 1.81 60ft
-On it's way to 11's....
Old 08-12-2006   #4
tnm27
I'm the short one.
tnm27's Avatar
i just bought a new alternator. it might just be the starter from what i've heard from other people.
Old 08-12-2006   #5
The starters don't die very often on a DSM. Check the voltage. How did you bleed the fuel system? It is possible you hydrolocked the cylinders with fuel. Take out a spark plug and check if there is anything in the cylinder.
Old 08-14-2006   #6
tnm27
I'm the short one.
tnm27's Avatar
well, today i took the starter out and got it checked at auto zone, it passed the test so that eliminates that. i checked all the wires, and got new battery terminals, but nothing has changed. it still won't start. is it possible that a fuse might of blown? if so than which one? and another thing i discovered today is that when i try to turn the car on. all the lights start to flash on and off for about 3 min. and than i hear a clicking sound from somewhere around the bottom of the drivers side seat. any one know about this?
Old 08-14-2006   #7
tnm27
I'm the short one.
tnm27's Avatar
o yeah, i relieved the fuel system by the Hyanes repair manual way. i removed the filler cap and than i disconnected the fuel pump electric connector, started the car and it stalled.
Old 08-14-2006   #8
tnm27
I'm the short one.
tnm27's Avatar
the spark plugs smelled of gas but none visible
