Old 09-03-2006   #1
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
Setting the thrust bearing.
What is the easyiest way to set the thrust bearing? How Do you guys do it?
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 09-03-2006   #2
tim
tim's Avatar
Re: Setting the thrust bearing.
Do you have the factory service manual? There is a good description in there.
Old 09-03-2006   #3
Capinoy123
Capinoy123's Avatar
thanks just went out and bought one!
Old 09-05-2006   #4
Set the caps at about 5 ft/lbs and tap the crank back and forth a few times. Hit it the final time towards the front of the engine and torque the caps to spec.
