Old 01-24-2004   #1
Wideband
Its only 350 bucks and its a true wideband, it doesnt say the brand or what the readout goes to. It also has a adapter you can buy so that you can hook a standard narrow band guage to the adapter and then it will readut wideband. Pretty cool.
Anybody know any more info on this or have seen it for sale anywhere else?
-Peter
Old 01-24-2004   #2
http://www.plxdevices.com/M-Series_productinfo.htm
Old 01-24-2004   #3
Scott (NSANE) just got one and is putting it i his car. I am sure he will chime in on it. He said Horsepower Freaks has it for about $320ish.
Old 01-24-2004   #4
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
This looks cool. I will deffinately be tapping my O2 for a bosch sensor when i have it at QPR.
Old 01-24-2004   #5
You can also just take out the stock O2 and put it in there. The threads are the same. The techedge V2 kit is about 50 bucks more, but also does datalogging and the display is seperate so it is smaller. Just another option to look at.
Old 01-24-2004   #6
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
How tough is it to wire that O2 to the wideband readout and the narrowband plug?
Old 01-24-2004   #7
Can the M-Series narrowband output be used to replace my stock oxygen sensor?
Yes, if your vehicle comes equipped with a standard narrowband oxygen sensor, you can use the narrowband output (gray wire) to feed that directly into your ECU. This eliminates the hassle of having to weld a second oxygen sensor bung onto your downpipe. PLXApp004 contains more details.
Old 01-24-2004   #8
Good system, its probably what I am going to run in my car, I've heard some good reviews of it, and bang for the buck, its very good.
