Old 10-07-2006   #1
Snafubmx234
Coolant loss, water pump or easier fix??
Haven't been on here for a while, but my friend's recent problem with his 2g has tuned into a hung pain in the @ss.
When he brought the car to me, it has a bad oil leak, and it was running very hot. Turns out the oil leak was a transmission bolt (bellhousing to engine bolt, thought it would be weird for oil to leak from there, but it fixed it). After this, we addressed his coolant loss problem. I did a compression test and got 175 all across the board. Exhaust isn't white, so I figured it's definitely not a HG. So, we fill his coolant up with a 50/50 mix, but before we spray the motor/crossmembers down with degreaser and rinse it with water. We find that he's losing coolant from the driver's side, so I'm assuming it's a water pump leak?
Since I'm a Honda guy, I'm not very familiar with this car. Do 2g DSM's have a common hose or some type of gasket that can go bad and cause a leak like this? Any help would be great. Thanks.
Snafubmx234 is offline   Reply With Quote
