Old 10-12-2006   #1
turboDSM
turboDSM's Avatar
Drives: tastefully modded BMW : )
wtf just happened??
Just to let you know I’m kind of new to the DSM thing, anyway I was driving down the road boosted up 2nd gear and the started to smell oil burring then I seen smoke, so I pulled over, the HG was not blown but there was oil all over and the dipstick was sticking up. Is it the PCV valve or what??
turboDSM is offline   Reply With Quote
Old 10-12-2006   #2
Re: wtf just happened??
Blowby, common on any DSM. Plus the o-ring on your dipstick is dry and shot. You can get a new dipstick from Brookdale Mitsu for a few sheckels.
Old 10-12-2006   #3
turboDSM
turboDSM's Avatar
what about the pcv valve?
Old 10-12-2006   #4
Nope not your problem, crimp the rod where the dipstick goes into a little bit so its tighter and it will solver your problem. This is very common on DSMs. Don't worry.
Old 10-12-2006   #5
turboDSM
turboDSM's Avatar
The dipstick has always popped up even after it was crimped, but today it blew up and shot oil everywhere.
Old 10-12-2006   #6
Gravy
Who's this guy?
Hapens on my car a lot. It's just a pain when you have to check your oil, but i would find some way to "Fix" it in there so it's hard to get out, but not impossible. I may be picking up new dipstick soon.
Old 10-12-2006   #7
twack
It was a auto get over it
twack's Avatar
Just a warning if you crimo the top of the dipstick it will hold the dipstick great at first but after using the dipstick alot it will chew into the rubber and then you be in my boad were i get blowby even with the stick in
Old 10-12-2006   #8
Spend the insane amount of $15 to get a new dipstick. The rubber seal hardens over time.
Old 10-13-2006   #9
Elementality158
Elementality158's Avatar
Send a message via AIM to Elementality158
Yeah. Get the new dipstick. I crimped mine. It made it worse. I made it kind of an oval and it just went out the sides.
Elementality158 is offline   Reply With Quote
Old 10-13-2006   #10
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
Agreed, new dipstick.
Old 10-13-2006   #11
Zip ties. Nuff said.
Old 10-13-2006   #12
Onefast99gsx
I just had this problem about 2 weeks ago. Oil was everywhere. I bought a brand new dipstick and went out for a beating and it did the same dam thing. Oil was everywhere. I ended up putting a tiny 1/4" hose clamp around the dipstick tube with a wire tucked into the clamp. Then i wrapped the other end of the wire around the dipstick handle. It AIN'T coming out now!!! Just don't wrap it around handle too many times so that it becomes a job to check the oil.
Old 10-16-2006   #13
dylan
Drives: .
weld dipstick to tube. only solution.
dylan is offline   Reply With Quote
Old 11-07-2006   #14
Krazy_boi05
Krazy_boi05's Avatar
this happen to me once, i tweaked my boost up to 15 psi and went for a spin, like yours, in 2nd gear, i started smelling smoke and when i went back to my house, opended up the hood and saw that my dipstick also popped out. all i did was tweaked my boost down to 12 psi and it didn't happen ever again, so i can just be that ur boostin too much.. but i'm new to dsm so i wouldn't really know.
Krazy_boi05 is offline   Reply With Quote
Old 11-07-2006   #15
Why must people argue about such a simple and common problem and insist on finding ghetto fixes when a cheap correct fix is available?
Old 11-07-2006   #16
You do realize you are not currently on the S2000 board, right?
Old 11-07-2006   #17
Maybe try turning your boost off? I think that's what chris is getting at...
Old 11-07-2006   #18
Hey this is in the tech forum.
Old 11-07-2006   #19
But we've decided its not a tech question since its been covered so many times and the solution is so simple (and has been stated 10 times over).
