Old 10-17-2006   #1
tjg
New problem!
Ok i was on my way to lunch at school today and i guned it in second gear and i started slowing down to the stop sign car was dead. Poped the hood ignition fuse is blown, replaced it quick started it up blew out again does anybody know why this is happing a wiring diagram would be helpful.
tjg is offline   Reply With Quote
Old 10-17-2006   #2
tjg
Re: New problem!
I'm gona check the grounds and battery connections first see if works, i'm sick of paying 2.77$ for those 30 amp fuses.
Old 10-18-2006   #3
tjg
Re: New problem!
I charged the battery clean the connections i found out that my broken speedo sensor slid between the halfshaft and the tranny and striped the wires wich i thought was the problem but i cut the wires taped them up and it still blows fuses. I put a fuse in start the car, runs for 2 seconds blows a fuse. Idk where to start for tracing wires do you think it could of gone farther up the wires or some place else.
Old 10-19-2006   #4
tjg
Re: New problem!
Well i fixed the problem, I feel like a idiot. I traced the wires further into the harness and found the break in the connection, so you can go ahead and delete this thread.
