Old 11-06-2006   #1
Arp nuts + crower springs = bitch
I'm having a helluva time getting the arp nuts onth their studs, as the corner ones interfer with the crower springs.
I tried lifting the head and slowly lowering it down while tightening the nuts, but to no avail.
Anyone else had this experience, and if so how did you remedy it?
Old 11-06-2006   #2
Re: Arp nuts + crower springs = bitch
I had a problem with them too... I had no choice but to "help" the washer down with a socket and hammer. Looked like it bent the edge of the seat a little, but nothing else. Not the way I like to do things, but I saw no other way.
Old 11-06-2006   #3
The washers i can get down there no problem, its the nuts that are rubbing the springs.
Old 11-06-2006   #4
Hmm, I can't remember... I don't remember the spring getting caught under the nut, but they did touch as I wound it down and just squeezed by.
Old 11-06-2006   #5
Are you sure you're using ARP nuts? I think they were 14mm 12-points. They're much smaller in diameter than the washers and even with the socket on them, is not as wide as the nut seat, or the washer. I didn't have any issues with mine and the crowers.
Old 11-06-2006   #6
Yes, 14mm 12pts and they are indeed smaller than the washers.
Not all of the holes are giving me trouble, just the corner ones.
It just occurred to me that this could be an issue unique to me since i'm using a 2g head with the holes drilled out to fit 1g arp studs. I'm sure the 2g arp stuff would fit, but its too late for that now!
I need to figure this out!
Old 11-06-2006   #7
You're an engineer, just redesign everything.
Old 11-06-2006   #8
You're a lot closer to an engineer than i am at this point!
Its been suggested i just shave down the nuts giving me trouble (about 1mm).
Its not the prettiest or even the best solution, but considering its just a static fastener it will probably work.
Old 11-06-2006   #9
Wierd. I had absolutely no problems with mine. I had to put the washers on first, but I have no problem with the nuts.
Old 11-06-2006   #10
^^ Are you using a 2g head?
Old 11-06-2006   #11
No, I guess I didn't know you were.
Old 11-06-2006   #12
C'mon people, if you're going to post in a tech thread, make sure you read all of the previous posts. Sorry to be an ass, but this will help prevent misinformation.
Old 11-06-2006   #13
Double nut two of them on a bolt and spin it down on a grinder until the base is even with the nut flats. I had to do it. It works fine.
Old 11-06-2006   #14
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
I had to have a friend at work lift my head up, while I slipped the nut over the stud on my car, when I re-did the HG, but then again, I only have a 1g head.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 11-06-2006   #15
Speedfreak
Drives: four tires
I've had to grind down the little flare on the base of the arp nut when doing studs in exactly your scenerio. As well as all the other tips such as: holding the head and and helping the washers by at the same time.
Old 11-06-2006   #16
I also have issue with mine and crower springs. I think the springs are the problem. Put the socket on them and give them a tap, they will pop over the spring coils.
Old 11-06-2006   #17
I'm sorry.
Old 11-06-2006   #18
I'm sorry.
Go stand in the e-corner.
Old 11-07-2006   #19
If the washer fits I do not see how the nut could not thread down, but if you need to shave the nut I would clean up the edge on the bottom so there is no added friction between the nut and washer.
Old 11-07-2006   #20
Shane55113
Now 20% less Racist
Shane55113's Avatar
You can place the washer in to the head before you put the head on so its sitting there, it'll usually stick b/c of the moly lube. But the nut is not as easy since you have to put it on after the head is on the car and the studs are through the holes.
Does any company offer a tapered progressive valve spring? i believe that would cure this particular problem for anyone who wants to do this same setup in the future.
