Old 11-30-2006   #1
please inform me about pro's/con's of dsmlink
I am going to use a 1G fwd manual trans wiring harness and install multiport FI on my car. I have decided this will be easier than using megasquirt, which i'll sell to a volkswagen buddy of mine.
I'd like to know a few things:
What year/type of ecu will I need?
What exactly is a DSMLink?
How does it "plug in" or whatever it does when you install it?
I will use a GM maft setup - I've seen it used with that and it's easy.
Are there any other good things to know when I do this? like What will I do for the CAS? is that just a hall sensor? Should I mate a CAS to a stock dist. and make that work? I'm sure it could be done. And What should I do for coils, can I make coil on plug work or single coil?
Thanks!
Andrew
Old 11-30-2006   #2
Re: please inform me about pro's/con's of dsmlink
You will need a 1G turbo EPROM ECU of any year (a few wires may need to be swapped depending on the year of the harness and ECU). DSMLink is all burned inside the ECU and then you'll need to hook up a laptop to that in order to tune and data log.
MAF-T will work well.
Not a clue about your CAS questions.
Old 11-30-2006   #3
rst95eclipse
Your CAS questions are pretty straightforward. I'm not 100% sure that the 1g does not have a distributor, but I'm almost certain that it does not (since I'm most knowledgable in 2g's). The hall effect CAS sensor is the most accurate CAS that Mitsu produced. It really shouldn't matter what CAS you use, but the hall effect (black top) is the most sought after. You can certainly make a COP setup work on a 1g. You can also go after the one coil setup as well (stock).
Old 11-30-2006   #4
1G was electronic ignition, no POS old-school distributor here.
The stock 1G single coil waste spark system is pretty strong, some of the EVO guys are even upgrading to it.
Old 11-30-2006   #5
Where is the best place to pick up one of the ECU's once i find out what year my harness is? That and the CAS, those are the only parts I think i'll have questions with or probs. here's a pic of it incase it matters.
Old 11-30-2006   #6
Here is a good place to start looking for a ECU and CAS.
Old 12-01-2006   #7
I might have one for sale in a couple months. It doesn't work right now, but I'm sending it out to get repaired.
Old 12-01-2006   #8
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Wiring harness?
Old 12-01-2006   #9
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
dsmlink.com has every answer to every question you could have regarding this issue. If you cant find it you can email them and they will correctly direct you to a place where you can find the answer.
pics or gtfo
Old 12-01-2006   #10
I have an eprom ecu, already socketed, and even with fresh caps!
I will need $150 and a replacement awd ecu for this trade.
Old 12-01-2006   #11
That sounds like a good deal, but I don't have said awd ecu. I can trade you some of my college books right now, otherwise, i'd have to look around.
Old 12-01-2006   #12
HiImBrian
HiImBrian's Avatar
I will say that I've called a ton of junk yards and done a lot of searching for a 95 eprom and the cheapest one ive found was $175. So i'd take up that deal if I were you man.
pics or gtfo
Old 12-01-2006   #13
Thor06
11 Seconds to Freedom
Thor06's Avatar
I have a 91 turbo AWD non-eprom ecu....
Old 12-01-2006   #14
tim
tim's Avatar
E-mail the dsmlink guys and see what they say. If it has been done and it is semi-easy to do they will tell you know who to contact. Simple as that. If you have someone to talk to that is in the DSMlink forums maybe they can help you.
Old 12-01-2006   #15
That is a great price for an eprom ECU. I might have a harness for you.
Contact LSE for that stuff.
Link is the shit.
