Old 12-04-2006   #1
150lb injectors
Just throwing this out there in case anyone here has already done all the research, or has any input. I'm looking for some larger injectors and have been doing a lot of research. I was looking at FIC's 1600 injectors, which sell for 85/piece. But I'm always looking to find a deal. So I've been digging for alternatives.
Apparently that MNGSX guy off Tuners is running these Crown Victoria 150/160lb injectors. I also found him posting this in some biodiesel forums and what not too. So apparently they are working ok for him. I'm trying to find the best deal on these as I can. The only thing, is that I keep seeing similar part numbers, but they sometimes have 1 letter difference, and it gets kind of confusing. So if anyone has some solid part numbers that they know will work, please let me know. Here's what I've found so far...
FIC 1600's=85/piece
I first started out with this part number, and these injectors. 74160
Summit
Autozone Then started finding all sorts of part numbers. Here they want like 87/injector which isn't much of a deal. So I moved on.
Then I found out the have them at Ford racing parts for 275/set of 4.
Now, I'll just continue to list the rest of sites I've found. I haven't verified these part numbers yet, but here's what I've come across...
gefracing 245/set of 4
PART NUMBERS CM4980, F5TE-B5A, XL3Z-9F593-CA(this is a part number I got directly from the local dealers part department), F5TZ-9F593-B5A,
https://www.rockauto.com/dbphp/mfr,M...,Fuel+Injector
apparently those are all the same basic part, just by different manufacturers, some with core charge... Looks like they have an injector that is as low as 31/injector with a core charge.
http://www.directautomotiveproducts.com/322a1402.html
35/injector, again we see part number F5TZ-9F593-B5A
http://www.fuelinjectorsdirect.com/wizard/default.asp
65/injector, and again we see familiar part numbers such as F5TZ-9F593-B5A, and F5TE-B5A
PART NUMBER C1000-147879
http://www.prostreetonline.com/catal.../fuelinjector/
and
http://replacement.autopartswarehous...jector&dp=true
OK, anywho, just trying to share a little of my research. I'm sure I'll get plenty of the "Why not skip it and just get the FIC ones". But I'm always looking for the deal, and doing things a lil against the norm. And like I said, I've already realised I'm not alone, one other person that I know of seems to be using these, and who knows how many more. Just looking for a cheap alternative. If anyone else has any info on this, please add to this. I'm just trying to sort out all the different part numbers. But from what I'm gathering, a lot of these part numbers, are in essance the same part, just some made by AC Delco, some made by GB-Sorenson, some by AirTek, etc.
