Go Back   MitsuStyle > Hosted Support Forums > Elite Autosport
Old 12-20-2006   #1
Speedfreak
Drives: four tires
Big Tex Auto Trailer for sale
I received this as a trade for labor. But I need the money more then a trailer at this point. It is the nicest open trailer I've ever seen. It is grey in color, and has added options. Details are below:
Diamond Back Car Hauler Tandem Axle Trailer - 70DM
GVWR: 7,000#
GAWR 3,500#
Coupler: 7K 2" Bulldog Coupler
Safety Chains: 1/4" Grd. 70 w/Safety Latch Hook (2 ea.)
Jack: 2000# Fold Up
Tongue: 2" X 4" X .188 Rectangle Tubing
Frame: 2" X 4" X .188 Rectangle Tubing
Crossmember: 2" X 3" X 3/16" Angle
Uprights: (none)
Fenders: 9" X 72" Tear Drop w/Back
Axle: Two 3500# EZ Lube w/1 Elec. Brake
Suspension: Multi-Leaf Spring
Tire: ST205/75-15" Load Range C
Wheel: 15 X 6 Chrome - 5 Bolt
Floor: 1/8" Diamond Plate
Lights: D.O.T. Stop, Tail, Turn and Clearance
Electrical Plug: 7-Way RV
Finish (Prep): Acid Etched w/White Phosphorus, Undercoated w/ Panther
813 & Two Coats Primer
Finish: Painted w/2 Coats High Solid Supreme Acrylic Automotive Grade
Enamel, and Pinstriped
Includes:
- Safety Chains Attached w/ Cold Rolled Eyelets
- Chamfered Front w/ Stop Rail
- Fold Back Tongue
- Fold-Up Jack
- Chrome Wheels w/ Chrome Caps & Lugnuts
- Dovetail
- 1/8” Diamond Plate Floor w/ Four Recessed D-Rings
- Two 3500# Axles w/ 1 Electric Brake
- 5’ Long x 20” Wide Diamond Plate Ramps Slide in From Rear
- Complete Break-A-Way System
- Spare Mount & spare tire
- Cambered Ez Lube Axles
10K Round Bar Weight Distributing Hitch Kit
• 1,000 Lbs. tongue capacity
• 10,000 Lbs. Gross Trailer Weight
• Easy installation
• No complicated adjustments or attachments
• Friction adjustment for multiple towing situations
• Easy to hook-up and remove
• For use with all Class III & IV receiver hitches
• Built-in right hand sway control platform
• Bolt together assembly
• E-coat base with black powder coat finish
• Hitch ball and sway control ball
• Shank (# 7350350 10" or # 9990042 12")
• Sway control (# 7350159)
Here is what it looks like, only a different color:
http://www.bigtextrailers.com/spec/70dm.html
The customer told me he paid something like $5200 for it, and has been used to haul his NSX three times, and that is all the use it has had. But I traded it for $3500 labor a few months ago. And would like to get at least $3000 for it.
