Old 01-05-2007   #1
Project Fast Spyder
This winter/spring I am doing a ton of Projects/MODs. This Thread will fill you guys in on it.
The Mods:
Built 2.4L
-Eagle Rods
-Wiseco Pistons
-ARP Head Studs
-ARP Main Studs
-ACL Bearings
-Cometic Head Gasket
-6-Bolt Main Girdle
-BS Elim
-All the Mitsu Timing parts and Front Cover
SS Fuel Lines(Possibly from the tank back to the tank)
Magnus Intake Manifold
Greddy Cam Gears
AEM Wideband Controller
Coil On Plugs
Pretty JMF Heatshield
SS Turbo Feed and Return(Both coolant and oil)
And Possibly
-HKS 280 Cams
-T-bolt Clamps all around
-Ksport Coilovers
-Aluminum Radiator
-Water Injection
-AWD
Now for the projects:
Rewire the whole engine bay to make it look clean, Split up the Big harness and make small ones that will blend in, Get rid of wire im not using(Soleniods, CAS...)
Move Ugly Underhood Fuse Box To Inside. That thing is ugly and makes the underhood look nasty
Here is where im at soo far
Picked up my Pistons, Rods and ARPs yesterday
http://www.mitsustyle.com/photopost/...m/CIMG1127.JPG
The Wire MESS! All Sorted out just need to wire loom it and disconnect the unwated wires and possibly shorten up most of the wires.
Let me know what you think.
